Brake light switch Problem
Old Aug 23, 2011 | 02:21 PM
Overstreet's Avatar
Overstreet
Default Brake light switch Problem
So I did a total rebuild on my truck and made some new brake lines which i had to take the brake booster off whats weird is i turned the key on and the brake lights have been staying on when the pedal is up and i push down on the pedal and it still stays on
I used my finger on the brake switch to move the plunger in and the lights turned off it seems like the pedal is not coming up far enough
could this be since i need to bleed the brakes
thanks everyone the beast should be started tonight !
Old Aug 23, 2011 | 03:26 PM
zman17's Avatar
zman17
Retired Moderator - RIP
maybe, bleed them and find out.
Old Aug 23, 2011 | 03:27 PM
Might just need to adjust the pedal, or the switch.
Old Aug 23, 2011 | 11:49 PM
angelo's Avatar
angelo
I had the same problem and I found out that the brake switch plunger was broken and was pushed in. Had to replace it
