WTF! odometer went crazy
Old Aug 24, 2011 | 10:01 PM
mgaither0's Avatar
mgaither0
Default WTF! odometer went crazy
So i was trying to replace the ac compressor and after a failed attempt due to the junk yard one I bought had a different connector on it which i realized after hooking everything up. So i took it off put the old one back on and called it a day. Hooked the battery back up and jumped in the truck. When I started the truck it went from 141k to 200k wtf! does this mean someone did something to the odometer and rolled it back some howe or is the truck being a bitch any idea whats going on? ??????? I'm lost rite now.
Old Aug 24, 2011 | 11:29 PM
JackJ's Avatar
JackJ
The PCM may have been replaced with one with a higher mileage truck, and they had it re-programed, AFAIK that is the only way to roll back a digital odometer. If this was just bought I would be going to the PO and raise some hell until the truth come out.
Old Aug 25, 2011 | 08:26 AM
Does the PCM store the mileage? Or the cluster?
Old Aug 25, 2011 | 08:52 AM
aim4squirrels's Avatar
aim4squirrels
I always thought it was the cluster. It was something you had to live with if you ever swapped clusters with another junk yard one, IIRC.
Old Aug 25, 2011 | 12:51 PM
mgaither0's Avatar
mgaither0
I havnt switched out the cluster or anything. I'm assuming the computer stores the milage but i could be wrong.
Old Aug 25, 2011 | 01:01 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
It depends. Does your truck have power seats?
Old Aug 30, 2011 | 06:45 AM
mgaither0's Avatar
mgaither0
no it doesnt have power seats.
Old Aug 30, 2011 | 06:47 AM
mgaither0's Avatar
mgaither0
The following day when I got in the truck the milage was back on 141k where it should be. I did have pep boys tell me the PCM was bad and needed to be replaced a few weeks back but I dont exactly trust pep boys they blow. I need to go to the auto parts store like advanced or auto zone and have them pull the codes. Pep boys said they couldnt pull the codes cuz my pcm was bad.
Old Aug 30, 2011 | 06:49 AM
mgaither0's Avatar
mgaither0
where is the PCM located in the ram? is it under the drivers seat? If this is indeed bad I could pull one from a junk yard and have it programmed rite?
Old Aug 30, 2011 | 07:05 AM
Novarider's Avatar
Novarider
It's on the firewall on the passenger side.
