Need help with ID on tranny
Old Aug 26, 2011 | 05:22 PM
  #21
taztech2010's Avatar
taztech2010
Smile Thanks Guys for Info
Ok, Im convinced, I'll be on the lookout for a 46RE, just picked up a healer pup, so will have to wait a bit yet.
Thanks for all the help guys, Will let you all If I need any more help.
See ya
Old Aug 26, 2011 | 05:53 PM
  #22
zman17's Avatar
zman17
Retired Moderator - RIP
Don't forget, 98 or 99, and from a 4x4.
Old Aug 26, 2011 | 06:44 PM
  #23
taztech2010
Any partic reason why only those years? I thought 96 to 2002 fit out of dingo, ram or jeep fit as long as 4x4 and 5.2 or 5.9
Just curious. Found a rebuild for 1000 plus core today 3 month 6000 mile warr. is That good or can I find better?
Thanks again
Old Aug 26, 2011 | 06:51 PM
  #24
Some of the sensors, and their associated connectors changed over the years. The newer trans would physically bolt right up, but, the electrical wouldn't be quite right, and you would have issues.
A grand for a QUALITY rebuild is a good price. If they have to ship it to you, I would pass, as if you have trouble.... nothing like being able to walk into the shop, and talk t someone face to face. If you want to order one online, spend a bunch more, and get one from a company that has an established reputation.
Old Aug 26, 2011 | 06:53 PM
  #25
zman17's Avatar
zman17
Originally Posted by zman17
98 or 99 only. Unless you want to change all the sensors inside. You'll also want one from the same drive as yours. 2wd or 4wd that is.
What he said already . You might be ok with a 96 or 97, but it's a lot of work, just to find out you need to do more.
Old Aug 27, 2011 | 06:33 PM
  #26
MonteC's Avatar
MonteC
wow. That was a rough read.
Old Aug 27, 2011 | 06:40 PM
  #27
zman17's Avatar
zman17
Agreed, so whats the verdict?
Old Aug 27, 2011 | 06:44 PM
  #28
xjarhead69's Avatar
xjarhead69
Wouldnt the easiest way to tell a 46re from 727 or 904 or 46rh would be the eletrical connector on the side? The 46re being 8 pin and the others being a 2 or 3 pin connector?
Dave
Old Aug 27, 2011 | 06:57 PM
  #29
zman17's Avatar
zman17
Dave
Yea, plus it aint gonna work with the PCM.
Old Oct 10, 2021 | 07:33 PM
  #30
Chris McCarty's Avatar
Chris McCarty
remember guys, the 46r(H) (hydraulic) is for the earlier models, the 46r(E) is for the electronic version. I think ‘98 was the cut year from hydro to electric
