no spark 1997 5.9 1500
ok guys this one is driving me nuts
i swap out my 1997 ram 1500 5.9 engine with a 2001 ram 1500 5.9 i installed a new coil new crank sensor and cam shaft sensor and change a few other sensor form old engine to the new engine and still no spark
i have tested the asd relay and changed it just in case and checked pin 30 i have power there
when i put my test light at the coil no power at all when cranking over i have tested the 2wires from the pcm to coil to make sure they dont have a break or shorts and still no spark
any ideas and help would be great and there is no cel on and the light does work
thanks james
thanks james
Then you are having an asd event.
Grab yourself a buddy. Park buddy in drivers seat. Get your meter out, and insert one probe into the power feed for the coil, ground the other probe. (meter set on 20vdc) Have buddy turn ignition to on, but, not try to start the truck. You should see power there for about 3 seconds. (a test light will work too......) Light should blink on for a few seconds, then off.)
yes grounds are all back to orginal spots
can some one give me a idea where all the ground go i have tryed a new pcm and still no start
Two on the front of the motor, by the power steering pump. Also ground wires at the back of each head, to the body. (I think)
Trending Topics
i cleaned the two grounds from valve covers on each side that go to firewall and the powertwo grounds on power steering bold and grounds on altanator bracket so my questions now is i was told it is a grounding issue the only one ground wiring not sure where it was orginally is one from the battery but not sure where it goes
I could be wrong, and I'll look in the morning(at my truck for you), but doesn't the negative from battery go to the alternator? (the thick one) and a thin gauge one goes to the radiator support.
