lift question
Old Aug 26, 2011 | 11:31 PM
DogeRamGuy1993's Avatar
DogeRamGuy1993
Default lift question
So i installed 2.5" coil spring spacers in the front about a month ago, and now i want to lift the back, i am looking at add a leafs on suspension connection and they have 2" add a leafs for 67.99 (pair) , i am really strapped for money so i asked the guy on the phone if i would need to buy 0-3" shocks and he said hold on and came back and said no (of course he would)
first question......would i need to buy 0-3" shocks?
and would i really gain 2" out of it?
thanks
Old Aug 27, 2011 | 01:07 AM
BackwoodsRam's Avatar
BackwoodsRam
youd maybe gain an inch with ad a fails, i have 4 inch aals and they only brought my rear end up maybe 2 inches and the ride sucks so bad now
Old Aug 27, 2011 | 09:04 AM
Depends on how much your stock springs have sagged.....
Old Aug 27, 2011 | 09:16 AM
zje400ex's Avatar
zje400ex
I put a 3" coil spacer up front and lifted the rear 2" and bought the rough country 2-3" shocks. You might be able to run the stock shocks, but i would recommend buying some for your lift size. I think mine were around $120 for all four.
When i was lifting my truck a few years back i wanna say that you need new shocks for anything over 2.5" up front and 0.5" in the rear. I could be wrong though. So you could get away with not having to buy any up front.
Old Aug 27, 2011 | 11:18 AM
merc225hp's Avatar
merc225hp
I am not a big lover of these but times are tuff;for your front shocks you could use a shock extender for a little while, for the back I would set the truck on the ground extend the shocks and see how much they extend past the mount 6"+ would be good, it must extend past the mount by at least 4" if not get two new shocks. If your leaf springs are in good shape the add a leaf will lift to the spec hight. I have add a leafs and airbags, load range e tires, yes it rides like a truck cuz it is a truck. Short shocks will limit Axel droop and flex so light wheeling only till you get the right shocks.
Old Aug 28, 2011 | 01:56 AM
Kraiger's Avatar
Kraiger
Another fix for the front is take off the factory three leg mount, cut out a circle of steel, drill three mount holes and a hole in the center for the shock, bolt it on in the place of the three leg mount.
Old Aug 28, 2011 | 08:32 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Well, if money is a problem, you can also just get blocks for the rear. And for 2" I think the stock shocks should be fine. From what I've read on here, 3" and up you want longer shocks.
Old Aug 28, 2011 | 06:02 PM
DogeRamGuy1993
i forgot to mention that i did buy 0-3" shocks from rough country (which by the way ride like crap!)
i would like to just do a block instead of aal's but we'll see, thanks everyone
