OBD fuse blows instantly, pcm port wont read, radio and over head lights wont work
Ok so I disconnected the battery and replaced thew iod fuse with the 10amp as it calls for. The second I out the negative cable on the terminal I heard sizziling. Opened the door looked at the fuse and its blown. Awesome.
Hmm. I would check both the right and left side door switches.
