do mechanics have ways to diagnose the possible problem without yanking the dash?
I would hope so. I ran a bottle of liquid copper through my radiator for a leaky heater core (awaiting the thread bashing...). My dash, like so many 2nd gens, is cracked up pretty good, I'm 100% positive if they had to remove it to fix the heater core I wouldn't have a dash to put back.
ok guys, heres one, 2000 dodge durango, got great heat, windows have just recently started fogging up and stay fogged up even with warm air blowing out. No ieaks on the floor, no wettness on the carpet, do smell the hint of antifreeze. Notice a ton of moisture coming from engine compartment as if a/c was on. What do you think?
Heater core needs replace
Originally Posted by VWandDodge
I don't know if anyone has suggested this, but it sounds like your heater core is leaking.
+1...... lol
Originally Posted by blackbeasst
not to hijack the op's thread, but what if there is no leak, no smell, no fogging, but yet the heat works but very sporadically and better on the low levels then high? still heater core?
Heater core partially clogged or blend door not working correctly. I think neater core.
