Changed Transmission Fluid
Old Sep 3, 2011 | 03:52 PM
  #21
24K on trucks that tow haul regularly, 100k on those that don't.
Old Sep 3, 2011 | 11:03 PM
  #22
kadetklapp's Avatar
kadetklapp
Have no idea how you even adjust them.
Old Sep 4, 2011 | 12:08 AM
  #23
rocky_mtn_ram's Avatar
rocky_mtn_ram
This is a decent method I've found if you only have a ft. lbs. torque wrench...or no torque wrench at all. This is the low/reverse band adjuster (the rear one). Turn the center bolt to adjust it and the outer nut to lock your settings in place.
Using slight pressure with the screwdriver, pry the lever up and down looking at the travel from its highest to lowest point. 3/8" of travel will do nicely. Lock it in.
Front band adjuster bolt and locking nut.
Turn the adjusting bolt hand tight and pry the lever lightly again with the screwdriver looking for around 1/4" travel here. Lock it in.
All credit must go to baxy from jeep forum.com. Those we're his pictures and his procedure for adjusting these bands.
Old Sep 4, 2011 | 12:11 AM
  #24
J415's Avatar
J415
Take a look at our DIY section.
