Fuel sync problems and P1391
Old Sep 5, 2011 | 07:07 PM
dodgeboy7's Avatar
dodgeboy7
Default Fuel sync problems and P1391
Been a while sence i been on here but been having power problems out of the motor just really low on horsepower. I hook up my snap on brick and check the fuel sync -10. HOLY HELL lol so got it set back to 0 and it was great ran like a bat out of hell. But only lasted about 10miles or so and started to make a rattle noise at higher rpms. Got home and notice the idle is really loopy like 500 rpm to 900 rpm. I also got the P1391 code to pop up. I checked all the wires for the cam and crank senor. I oms out the wire between the sensor and pcm and i also checked for the 5v. Every thing is right on. After all of that i am lost.
Old Sep 5, 2011 | 07:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Maybe one or the other is simply bad? You can test them until your blue in the face, and that doesn't mean they are working correctly, like the PCM wants them to..
Old Sep 5, 2011 | 07:34 PM
aim4squirrels's Avatar
aim4squirrels
Rattle noise at higher RPMs may very well be spark knock.
Have you ever fixed the plenum gasket?
Old Sep 5, 2011 | 07:58 PM
dodgeboy7's Avatar
dodgeboy7
I already replaced the crank and had a spare dissy out of my parts truck
Originally Posted by aim4squirrels
Rattle noise at fogger RPMs may very well be spark knock.
Yes aim i fixed it with the hughes kit and i just checked it agian and it still nice and clean but yes it sounds like a spark knock
Old Sep 5, 2011 | 10:39 PM
aim4squirrels
I'd run some seafoam thru the intake to blow out the carbon.
Old Sep 6, 2011 | 06:43 AM
dodgeboy7's Avatar
dodgeboy7
I don't think it carbon the motor only got 20,000 miles on it
Old Sep 6, 2011 | 07:46 AM
aim4squirrels
Then I would wager you've got I one of the lesser common problems like a bad coolant temp sensor or the like.
Old Sep 6, 2011 | 08:29 AM
P1391 Interm Loss of CMP or CKP
If you have already replaced both sensors.... then you either got a bad one, or, you have a wiring issue somewhere. Did you check/clean the connectors at the PCM?
Where did you get your new crank sensor?
Old Sep 6, 2011 | 08:58 AM
dodgeboy7's Avatar
dodgeboy7
How is a bad coolant ten going to throw that code and my sync off and I got the crank sensor at Napa and then switch to a molar and just got done checking all the wires
Old Sep 6, 2011 | 09:49 AM
dodgeboy7's Avatar
dodgeboy7
