major power loss
Old Sep 6, 2011 | 05:47 PM
scrappy2686's Avatar
scrappy2686
Angry major power loss
ok so i have a 96 ram 1500 with a 5.2, we got the truck to use as a shop truck but it has no power at all. it idles fine and i have replaced the IAC the MAP sensor and TPS but yet when i mash on teh gas in idle it will stop about 2000-2300 rpms and will not go any higher. can anybody help with this interesting situation that i have encountered. fule problem maybe?
Old Sep 6, 2011 | 05:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Sep 6, 2011 | 05:59 PM
scrappy2686
thanks zman. i am going to tear it all down tommorrow and see if that is actually it. i hope so.
Old Sep 6, 2011 | 06:03 PM
zman17's Avatar
zman17
Unscrew the precat o2 from the pipe and see if it runs any better. (not sure if that's in the thread or not)
Old Sep 6, 2011 | 07:13 PM
scrappy2686
ok so O2 is out and is revving all the way to redline now, so does that mean bad o2 or clogged cat
Old Sep 6, 2011 | 07:29 PM
gdstock's Avatar
gdstock
Means plenum is blown, and cat may be plugged. Check plenum with a magnet. I would bet it has the original steel plate (and blown gasket). I just received new aluminum plenum plate today ($49.99 on eBay). Best price I could find.
Old Sep 6, 2011 | 07:37 PM
jmhai's Avatar
jmhai
Fix the plenum, replace the Cat and get a new front o2 sensor and you should be good to go....
Old Sep 6, 2011 | 11:08 PM
And don't forget the tune up while the intake is out of the way.....
Old Sep 7, 2011 | 03:07 PM
scrappy2686
ok so intake plenum is off and gasket was sure enough blown. was on a budget so couldnt get a new plate but i think i may put a small bead of rtv just to be safe. total tear down was under an hour cause it helps being small and being able to fit in the engine bay lol. will let yall know the results when i get everything put back together, just waiting for parts to come in now.
Old Sep 7, 2011 | 03:12 PM
zman17's Avatar
zman17
If your going to do it without buying a new plate. Use a Felpro gasket and cut those **** off the end of the bolts(they are too long). And make sure the thread holes are clean all the way to the bottom. Use loctite on them, and torque them more than once. I hope you have a manual for the torque procedure.
