need help finding wut i can do next on mods
Old Sep 10, 2011 | 12:06 AM
Adobedude's Avatar
Adobedude
Ditch the TB Spacer, chrome mirrors and Terd Bars...Your truck wil love you for it.
Old Sep 10, 2011 | 01:22 AM
gdstock's Avatar
gdstock
Since I'm a new Ram owner, I don't know that a TB spcaer is supposed to do. But I have been hanging around long enough to learn from everyone here that the kegger mod is worth doing - and every stock plenum pand either has or will fail. And it appears that they fail pretty soon. But that's just my begginer knowledge. I haven't driven mine more that 80 miles when I picked it up, and I already did the kegget mod on an extra intake, and will be putting it one within the next week, along with capp, rotor, plugs and wires.
Thanks to all that have helped me learn what I need to do - I am wasting no time.
Old Sep 10, 2011 | 10:08 AM
Throttle body spacer was originally designed for carbed applications. It sits between the carb (or throttle body), and intake manifold, and is supposed to lend a bit more 'swirl' to the incoming air/fuel charge, to keep the fuel in suspension better. It actually DOES work to a limited extent on carbed engines, and on Throttle body injected engines. (where there actually IS fuel in the air charge going thru it.) On port injected engines, like ours, there is NO fuel in the incoming air charge, so, all it does is swirl the air a bit more, and give you clearance problems with you air filter housing. There is zero performance gain. None. Nada. Zilch. (unless you want to count the .00000001 second you may pick up in the quarter mile from your wallet being lighter..... but of course, that is offset by the weight of the tb spacer. and if you pay be credit card? Well, you are just screwed.)
Old Sep 10, 2011 | 01:37 PM
Ugly1's Avatar
Ugly1
HeyYou. Since the TB spacer is on the intake side of the TB could it be slightly altering intake tract length in the same way pwer profiles are altered leading builders like to play with runner length on intake manifolds? Intake tract length is one of those things I've never gotten my head around why it may matter some places but not others such as air filter tract length for example.
Old Sep 10, 2011 | 01:54 PM
Runner length is what you are referring to, but, no, the runners don't start until the air has traveled a pretty good distance (as these things go) already in the empty space above the the runner intakes. It is the enclosed length there that the pulses generated by the air moving/stopping as the valve opens/closes that make the difference. Anything that happens prior to that, won't matter. (well, aside from going thru a blower of some sort. )
Old Sep 10, 2011 | 03:00 PM
Ugly1's Avatar
Ugly1
Ahh thanks HeyYou I shoulda known it's some of that pulse pressure/CFM kinda stuff which is always feels so much above my head. Reminds me the conversations I see the two stroke expansion chamber designers talking about on some of the bike pages I look at. All that stuff seems like voodoo witchery to me but I still listen and try to learn. Maybe someday when I'm way to old to ride I can finally understand enough to design pipes to help me win.haha!
Old Sep 10, 2011 | 03:15 PM
surferguy12's Avatar
surferguy12
Originally Posted by dodgeman2289
trying to do more to my truck but im stuck. looking for small cheap mods dont have the funds for heavy and big mods. signature shows wut ive done so far. just need alittle help
sell the step bars definitely and do interior mods like lighting or underglow in the wheel wells above the tires and front grill, train horns, tonneau cover, nos,flamethrower exhaust with the flowmasters would be sick! but its all wat u like on your ride man i basically powdercoated my stock sport rims with engine primer, works awesome did it a year ago and no flaking or chips, but have fun
gdstock's Avatar
gdstock
Thanks, HeyYou. I googled it to see what it was, and I suspected it was some the voo-doo stucff like Ugly1 was saying.
Don't ask-can't learn!
Thanks.
Old Sep 10, 2011 | 03:31 PM
Wait, what? You mean its NOT magic??
