Need Caspers IAT ext cable, Part#?
Old Sep 8, 2011 | 06:28 PM
beeker's Avatar
beeker
Default Need Caspers IAT ext cable, Part#?
Does anyone know the part number for the Caspers IAT extension cable? I can't seem to find it. All the cables on their site just say it's for Dodge, no specifics. I'm installing Hughes F1 intake and would like to relocate to the unused port in the intake under the throttle body.
Old Sep 8, 2011 | 06:32 PM
pcfixerpro's Avatar
pcfixerpro
call moes and ask
http://moesperformance.com/index.php...ducts_id=12182
Old Sep 8, 2011 | 08:59 PM
Erm, you can't just screw it into a hole ya know......
Old Sep 10, 2011 | 04:32 PM
beeker's Avatar
beeker
Yes I know, I want to try placing it in the air inlet tube and then try it in the intake as well because I've heard it can advance the timing a little due to reading the cold air temperature(which I don't think I want). I decided to untape the wire harness and pull the IAT wire out more. No need to buy a special harness extension.
Old Sep 10, 2011 | 04:42 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Anything for worse MPG's.
Old Sep 10, 2011 | 05:01 PM
beeker's Avatar
beeker
What do you mean, placing in the Hughes intake will cause worse mpg? Where do you suggest is the best place for it?
Old Sep 10, 2011 | 05:15 PM
drewactual's Avatar
drewactual
Air hat, close to tb mouth..
The IAT can advance 3*, and retard the same.. could be difference in a ping, or cost you a few ponies.. it also has bearing on fuel trim.. the warmer it reads the less fuel it adds.. if it reads cool it will add fuel and you'll run rich.. rich will cost you economy, and is hard on o2's and cats.. the o2 will ultimately discover the deception and curve it back, but to run optimum, you'll want all sensors agreeing.. do that by getting accurate reading... So put it on the hat near the tb port.
Old Sep 10, 2011 | 05:23 PM
beeker's Avatar
beeker
Perfect, then that's where it'll go. Thanks!
Old Sep 10, 2011 | 06:02 PM
drewactual's Avatar
drewactual
I mis spoke.. the IAT can advance 1.5* and retard 1.5* for a total of 3* movement.. everything else I think is accurate..
