Persistant Misfire
Old Mar 31, 2012 | 12:41 PM
  #21
bigyeller's Avatar
bigyeller
I put a coil on it the other day and it still did it right after. But now a day later its not doing it but its also a little cooler out
Old Mar 31, 2012 | 12:43 PM
  #22
bigyeller's Avatar
bigyeller
And would it take a drive cycle for the computer to fix the problem
Old Mar 31, 2012 | 12:51 PM
  #23
Depends on what the original problem was. You could try just resetting the computer... (disconnect the battery for a few minutes) and see if that doesn't improve it's attitude any.
Old Mar 31, 2012 | 02:34 PM
  #24
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by bigyeller
Mine is doin the same thing but on cylinder 7 under a load in overdrive. My compression is at 150 and fuel pressure is at 50 psi. I changed plugs wires cap rotor fuel injector coil. Checked the cat and o2 sensor. Ohmed the injector wire to the computer and also the injector itself. Even did a voltage test. Is there anything else i can look for.
Exactly how did you check the cat?
Old Mar 31, 2012 | 08:35 PM
  #25
bigyeller's Avatar
bigyeller
You can take a low pressure psi gage and get a few fittings from a hardware store and a spark plug nonfouler. 14mm and start the engine and it shouldnt read more than half a pound if it does the cat is bad.
Old Mar 31, 2012 | 08:36 PM
  #26
bigyeller's Avatar
bigyeller
Truck is fixed.
Old Mar 31, 2012 | 09:05 PM
  #27
Truck is fixed.
What fixed it?
Old Mar 31, 2012 | 11:19 PM
  #28
gdstock's Avatar
gdstock
What fixed it?
I am wondering also!
Old Apr 1, 2012 | 04:09 AM
  #29
bigyeller's Avatar
bigyeller
I unpluged the coolant temp sensor wich puts the computer into base time. Then i took my scanner and read the ignition adv. ° and it was around 27° so i turned the distributor till it was 8 to 10° adv. Thats it. Just had me thinkin how it got so advanced
Old Apr 1, 2012 | 07:55 AM
  #30
redneck_ram's Avatar
redneck_ram
the dizzy doesnt control timing, it controls fuel sync, you just messed up you fuel sync terribly.....
