Which tire size is correct?
Old Sep 15, 2011 | 09:00 PM
dadslittleredtruck's Avatar
dadslittleredtruck
Default Which tire size is correct?
On my 97 1500 2WD, the sticker on the driver's door column calls out the tire size as 225/75R16, but the Dodge build sheet shows is was originally sold with 245/75R16s.
And to complicate things further, there are apparently three tire sizes that could go on the truck: 225s, 265s and 275s, all 75R16s. This is according to Tire Rack and Ebay's Tire Center.
So which one is correct, the door column, the build sheet or the tire seller?
Which size would you use?
Thanks!
Old Sep 15, 2011 | 09:10 PM
Build sheet.
My door sticker says 245's, my build sheet says 265's. I have 265's on there, and the speedometer is pretty damn accurate. (according to the radar trailers the sheriff's department sets out for me. )
MoparMan1991's Avatar
MoparMan1991
I would use the 265s or the 275s. Wider tires = better traction patch = better driving. My durango came from the factory with 265s and the sticker said 235 so I know your Ram would be able to fit at LEAST 265s.
Old Sep 15, 2011 | 09:13 PM
I think you could go as far as 285's (roughly a 33" tire) and the only real concern would be rubbing on the control arms at full lock.
Old Sep 15, 2011 | 09:25 PM
MoparMan1991
I honestly would go with the biggest tire you feel comfortable putting on. I just got some 235/85R16 E Goodyear Wrangler Authority's and I love em, I just with they would have put on the right size tire that I asked for. Stupid walmart techs tried to tell me what wouldn't fit and then they took two hours to install and balance 4 tires. Ridiculous.
Hans_GZP's Avatar
Hans_GZP
I run 315's with no rubbing on my 2500. I don't think it's stock ride height though.
Old Sep 15, 2011 | 09:42 PM
3/4 and one ton trucks sit a couple inches higher than the half ton guys.
Old Sep 15, 2011 | 09:46 PM
Hans_GZP's Avatar
Hans_GZP
I had the OEM 20 inch wheels and tires from a 3rd gen ram on my 94 1500... they rubbed slightly when at full lock.
Old Sep 15, 2011 | 11:36 PM
Rob59's Avatar
Rob59
Fairly certain my door sticker says 225's, but i bought it off my dad who bought it new and it came with 265's, still even have the original spare underneath that is a 265.
265's are your best bet imo. Will give you the best ground clearance and look without sacrificing power due to (presumably) 3.55 gearing. Either tire size will work fine, though. About the biggest you could fit at stock height is 285, but those might rub (im sure someone here can say for sure) and will probably have you wanting steeper gearing.
Edit: You have a 2wd, 285s would be too big.
Old Sep 16, 2011 | 12:09 AM
dadslittleredtruck
Never thought to look at the spare. 265s it is, then. That also might explain why the speedometer says 55 and the GPS says 58, huh?
Thanks, fellas!
