gaaahhhhh this cant be happening
Old Sep 16, 2011 | 01:03 AM
JSTMoto's Avatar
JSTMoto
All I've ever read about Gatorback's in our trucks is that in some instances they like to squeal more than normal. I had that same problem on a different truck with a Gatorback, so IMO they aren't worth spending any extra money to get. On the other hand, I've read nothing but good reviews about Dayco belts in our trucks.
Why didn't you stop and pull over when you realized you lost your belt?
I hope your drive home wasn't a long one because you made the drive without a functioning water pump. As crack happy as our cylinder heads are, I wouldn't have risked it myself if it would have been more than a few minutes away.
*edit - Ahhh, i see where you mentioned being 5 miles away now...
Old Sep 16, 2011 | 02:05 AM
Mpi360's Avatar
Mpi360
Originally Posted by jasonw
Uh, no it will not. Not sure who stated that, but they were incorrect. I have been running a Gatorback on my truck for the past 5000+ miles or so, no problems at all. The tensioner and water pump I bought, on the other hand, I am having second thoughts about...
Umm RM-INDY. Underdrive or not i wouldnt run one and all he did was start it.
https://dodgeforum.com/forum/2nd-gen...pulleys-2.html
Old Sep 16, 2011 | 02:52 PM
UnregisteredUser's Avatar
UnregisteredUser
The Gatorback on my truck has been going round and round just fine for several thousand miles now.
Old Sep 16, 2011 | 03:29 PM
drtbker13's Avatar
drtbker13
where were you in this picture just curious?
Old Sep 16, 2011 | 03:33 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Sounds like a case of mis-aligned pulleys. It's happened to me after having replaced the power steering pump.
Old Sep 16, 2011 | 03:55 PM
UnregisteredUser
In my signature photo? That's on Kodachrome Road, just east of Las Vegas, Nevada, between Vegas and Lake Mead.
Old Sep 16, 2011 | 05:12 PM
aim4squirrels's Avatar
aim4squirrels
Indy also stated he was running a different pulley set and doing some experimenting.
I've not heard much about those belts good or bad.
Old Sep 16, 2011 | 07:47 PM
redneck_ram's Avatar
redneck_ram
ok, after having put my old belt back on, the belt is on all the grooves on all the pulleys except for the crank pulley. it is off by one groove. any opinions. i went and returned the belt to advance, and stepped it up a notch and got a dayco instead. should i replace the tensioner? this is an all-of-a-sudden thing. ive gone almost 10k since i replaced my p/s pump and this is the first that anything has happened with any belt.
Old Sep 16, 2011 | 07:52 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Make sure the belt and ALL the pulleys have the same amount of grooves. There are 6 and 7 groove pulleys and belts.
Old Sep 16, 2011 | 07:56 PM
redneck_ram
all my pulleys are 7 groove pulleys, and i bought a 7 groove belt. wondering if its the tensioner, or if it could be the harmonic balancer.....
