gaaahhhhh this cant be happening
Old Sep 17, 2011 | 06:44 PM
  #31
redneck_ram's Avatar
redneck_ram
Have a look from the side, and see if you have a pulley misalignment somewhere. It really shouldn't do that......
there are only 2 things that that i have noticed, because i did look from the side the entire time. is that when the truck is started it immidiately jumps a rib only on the crank pulley. i shut the truck off as soon as i see it(remote start) and that the belt has moved a bit on the w/p pulley. could this be a bad idler or tensioner, or both?
again this just started happening, just a couple weeks ago. it has been fine up until then. so im thinking that its one of the pulleys.....
Old Sep 17, 2011 | 07:13 PM
  #32
redneck_ram
well i think i figured it out. need a new water pump! took the old belt back off and the water pump is all over the place, new one will be bought tomorrow!
Old Sep 17, 2011 | 07:19 PM
  #33
redneck_ram
also, should i replace that little hose that connects to it? its the bypass hose correct?
Old Sep 17, 2011 | 07:22 PM
  #34
That would explain a lot..... and yes, you should.
Old Sep 17, 2011 | 07:51 PM
  #35
redneck_ram
What else should i replace? I know i need the wp gasket and bypass hose. But what else.... Oh and i hate being on here with a cell phone IT SUCKS!!!!!!
Old Sep 17, 2011 | 08:04 PM
  #36
aim4squirrels's Avatar
aim4squirrels
whoa, did I read the wrong thread and respond? LOL, sorry about that.
Old Sep 17, 2011 | 08:41 PM
  #37
lastrights's Avatar
lastrights
Timing chain would be good to change out , double roller is 40 bucks
Old Sep 17, 2011 | 09:24 PM
  #38
redneck_ram
please point me in the direction of a 40 dollar double roller please!
Old Sep 18, 2011 | 12:33 AM
  #39
JSTMoto's Avatar
JSTMoto
I'm surprised your water pump wasn't leaking coolant if the bearing was bad enough to make the belt slip off.
At least she made it as far as she did for you.
Old Sep 18, 2011 | 05:56 AM
  #40
redneck_ram
yeah me too! poor girl has about 175k on her, and as far as i know its the original pump!
