truck hesitated to move why?
Old 09-19-2011, 12:52 AM
2000ramsport's Avatar
2000ramsport
2000ramsport is offline
Question truck hesitated to move why?
I was at a stop sign tonight and I stepped on the gas kinda hard from a dead stop and the truck hesitated to move and the front of the truck shook.whats up with that?I havent owned the truck more than a month and im wondering if this sounds like it needs a tuna up before I go buy everything.I couldnt get it to do it again but it was really odd.you think if it is a tune up i should start with new plugs and wires or what more?need info thanks
Old 09-19-2011, 08:36 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
Transmission issues. I bet the torque converter is slipping.
Old 09-19-2011, 12:28 PM
chadhager03's Avatar
chadhager03
chadhager03 is offline
Is that expensive to replace? Mine did that the other day
Old 09-19-2011, 06:52 PM
2000ramsport
Oh man I hope its not that.That would be big $$$$ grrrrr.
Old 09-19-2011, 07:03 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,214 Likes on 2,965 Posts
If the torque converter fails, it likes to distribute little bits and pieces of itself throughout the transmission, so, simply replacing it is like putting a bandaid on a sliced artery. Not only will you STILL have to rebuild the trans, but, you will get to replace the t/c again, as you can never clean them out completely, and re-using your new one will just wipe your trans again within weeks. Not a good plan.
It could also just be some solenoids going bad..... check those first.
Old 09-19-2011, 08:35 PM
chadhager03
Without googling it, is that easy enough for most anyone who knows how to change the transmission fluid?
Old 09-19-2011, 08:43 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
^no. you have to remove the transmission (or engine).
don't jump to conclusions. hesitation and shaking can be as simple as a tuneup.
Old 09-19-2011, 08:50 PM
chadhager03
I've done a tuneup..... But I lost my mind and have been checking my transmission fluid with it on in park. It's been a little low for a bout a month now but it seemed to have made it better.
Old 09-19-2011, 11:01 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
No, no, no.
Wrong procedure.
You get the engine and transmission up to operating temperature, cycle it through all the gears pausing for approx. 30 seconds in each, then you drop it into neutral, and THEN you read the fluid.
If you have to add more fluid, wait at least 10 minutes for all fluid to drain back into the trans, if need be drive a little bit to warm everything back up, repeat the first steps, re-check the fluid.
Sometimes transmission hesitation is caused by low fluid. Checking the fluid is the first step in diagnosing this mess.
Old 09-19-2011, 11:12 PM
gdstock's Avatar
gdstock
gdstock is offline
You do not have to pull trans to change governor solenoid or pressure sensor. You do have to dran and remove pan (usually taking a bath in ATF - good time to install drain plug).
I would go to DIY section and download a manual and do some reading before I would spend a lot of money just changing things. But if it is trans, don't take the cheap route. As HeyYou stated, "bits of itself all over..."
Quick Reply: truck hesitated to move why?
