v10 RAM no start....frustrated
Old Oct 21, 2024 | 10:57 PM
  #101
Squarrelygirl's Avatar
Squarrelygirl
Default Hmmm
It's not throwing the code for the crankshaft since I put one in but now it won't start
Old Oct 22, 2024 | 10:16 AM
  #102
Originally Posted by Squarrelygirl
I can hear my fuel pump engaging when I turn the key to on. I read that you are correct most of these trucks don't have a mass airflow sensor but the 96 V10 gas engine does. I sure hope so cause I ordered one that said it was for my truck. It was not easy to find either. Maybe I'm wrong I guess when it gets here Ill find out for sure lol. I tested my spark plugs with the little tester you out on the coil and then connect to the spark plug wires. As I'm saying that I think I may have done it wrong. Should I have put that tester on the spark plugs not the ignition coil? I checked all my injectors with a multimeter and they were all good.
There is no MAF sensor listed for the 96 trucks at all, in the service manual.. It is a speed density system, MAP sensor. There is no MAF.
Old Oct 22, 2024 | 04:01 PM
  #103
Squarrelygirl
You are 100% correct. I was given the wrong information. And sold a part that my truck does not even have. So should I have put the tester on the spark plug instead of ignition coils
Old Oct 22, 2024 | 08:47 PM
  #104
Location doesn't really matter. So long as you are getting spark, it's all good. But, if you ARE getting spark...... are you getting fuel pressure? Injector pulse? Are ALL of the coils firing? (one coil fires two cylinders, so, five coils to test.)
Old Oct 23, 2024 | 12:54 AM
  #105
Squarrelygirl
I got a wire tester and found a bad wire going to the crankshaft. I fixed that and she started!!. Now I'm curious to find out if the crankshaft and can sensor replacement is going to keep her engine from shutting down while I'm driving. Only time will tell.
