v10 RAM no start....frustrated
Old Sep 26, 2011 | 03:50 PM
  #51
ttrash91's Avatar
ttrash91
pulled asd relay and it is still a ground....checking under coloumn wires next
Old Sep 26, 2011 | 04:02 PM
  #52
ttrash91's Avatar
ttrash91
checked wires under couloum cover....no visual signs of breakage or loose connections
Old Sep 26, 2011 | 04:06 PM
  #53
Should have some resistance....... that wire DOES provide power to O2 sensor heaters, and the field windings on the alt as well.
Old Sep 26, 2011 | 04:25 PM
  #54
ttrash91's Avatar
ttrash91
would o2 sensors shorted fry the computer?
Old Sep 26, 2011 | 04:36 PM
  #55
zman17's Avatar
zman17
Retired Moderator - RIP
Too bad, God forbid it was something easy. LOL
Old Sep 26, 2011 | 04:43 PM
  #56
I don't know.... there should be some resistance across the heaters... (one would think.....) Got a VOM? Can you check resistance to ground?
Old Sep 26, 2011 | 04:44 PM
  #57
ttrash91's Avatar
ttrash91
checked the pwer/ grnd situation at the coil pack....has ground now at where pwer is supposed to be ....unhooked driver side o2 sensor and the ground is gone
wtf?.....seriously do i have an o2 sensor heater that is grounding thru the computer frying it ...come on now
Old Sep 26, 2011 | 04:46 PM
  #58
Welp, plug in a good PCM, and see if it will run now........ That does seem seriously odd though. One would think that dodge would be aware of just such a possibility, and plan accordingly.... but, strange as it may seem, I have been wrong before..... *gasp*
Old Sep 26, 2011 | 04:47 PM
  #59
ttrash91's Avatar
ttrash91
probly another 2-3 days for a pcm....pulling hair out here
ordered new pcm, be here by wednesday....
Old Sep 27, 2011 | 04:42 PM
  #60
ttrash91's Avatar
ttrash91
installed new pcm from carquest today and no start
no fuel pump prime
no check engine light bulb test
great....i guess to start all over is what next
