v10 RAM no start....frustrated
Old Sep 29, 2011 | 05:31 PM
  #71
ttrash91's Avatar
ttrash91
tranny doesnt start in 1st gear, swapped trans relay with different relay and started in 1st but didnt shift out of it....i'm gonna get the correct relay for in there and go from there.
it acts like it starts in 3rd. if i manually go to first, it goes dropps to 2nd and i can shift to drive and it hits 3rd, od button works sometimes, but others it sticks on and i can switch od in to gear
  #72
ttrash91's Avatar
ttrash91
what does trans relay do?....check engine light is off but codes are stored in tranny
Old Sep 29, 2011 | 05:50 PM
  #73
zman17's Avatar
zman17
Retired Moderator - RIP
Sorry, I for one am not knowledgeable enough with transmissions to give you a good answer. Other than replacing the solenoids and checking wires(interior and exterior,tranny) and the plugs/connectors. From what I've read here, the TC could be bad. Wait for MonteC to reply or start a new thread he might see. Good luck, hope it works out cheap.
Old Sep 29, 2011 | 10:17 PM
  #74
fargo39's Avatar
fargo39
i wonder if that ecu is for a standard trans? must be a good day for v 10 s i just got mine going today as well. what kind of scanner are you using? can you bring up any data on a test drive
Old Sep 30, 2011 | 06:27 AM
  #75
ttrash91's Avatar
ttrash91
some live stream data on my little ****ty scan tool, i don't think i can look at tranny stuff though
Old Sep 30, 2011 | 11:01 AM
  #76
ttrash91's Avatar
ttrash91
https://dodgeforum.com/forum/attachm...1&d=1317394619
I THINK THIS IS MY CULPRIT
Old Sep 30, 2011 | 01:58 PM
  #77
zman17's Avatar
zman17
Yea , that might be the problem.m
Old Sep 30, 2011 | 04:22 PM
  #78
ttrash91's Avatar
ttrash91
after such time in a horrifying event , i have finnally fixed the 96 ram v10, the transmission 8 pin plug was destroyed in what looks to be rodent activity....
after 1 hr in a dodge boneyard i found a nice clean wiring harness that i dismanteled with my dikes, return to the shop solder and heat shrink 8 wires, n the job is done
shifts smooth runs great, down shift good, od button works perfect....no check engine lights no codes , just a smooth running v10 machine
thanks dodge forum!!
p.s. _ i think i pissed about 12 hrs on it...but well worth it to me, should pull the camper perrrty nice!
Old Sep 30, 2011 | 04:37 PM
  #79
zman17's Avatar
zman17
Awesome man, feels good huh?
Old Sep 30, 2011 | 04:58 PM
  #80
CONGRATS!!!
Enjoy it in good health, and stay warm and dry on the way to work.
