Need Help Truck Stalled In An Intersection Twice!!
LOLOLOL. But zman, it just wouldn't be YOU if you didn't argue with me.
Albeit, most of the time, you give me a good chuckle, you don't go out of your way to **** anyone off, and certainly not me. Maybe feed me a ration of **** on a regular basis, but, if you didn't, I would think you didn't like me any more.
Shhhh, I was just saying that for the benefit of the big plan.
You know, NTO New Troll Order !
Well I got some good news, the picture really helped and when I got to work I took a look, and the CTS was unplugged, could pulled it out when I did the valve cover gasket, my truck was running better but it was a little chilly out and my truck ran a little better with the problems when it was cold. Tomorrow ill see what it does when its warmer. Ill still do the DIY on the IAC this weekend.
My D has been doing the shut down at intersections and while driving as well. I pull the ground off the battery for a few then it starts but in some cases i have to wiggle the 32pin connecter (the one closest to the firewall) on the pcm and it starts but sometimes when i lt go of that connecter it dies. New pcm?
Ill pull the cables and see what it does, last week sometime i got off work and my truck turned over once and died, the negative cable was loose, i fixed that but the problem was still there before that happened. I ll check the connection as well and get some electrical grease for it tomorrow. Its my day off
Huh? My head hurts now. LOL
