Glad you were able to see the photos. Yes, The truck is running much cooler. Now I have to fix the next problem. Ticking noise coming from passanger side of engine. Sounds like a rocker arm.
I wonder if maybe the tap water is really high in minerals too in your area. Maybe using distilled water would be a good idea? I also wonder if some stop leak stuff was put in there causing that too.
