Transmission question
Old Sep 23, 2011 | 01:30 AM
madmax0r's Avatar
madmax0r
Default Transmission question
Hey all
I have a ram 1500 4x4 offroad sport 5.9 with the 46re auto...
for the last few years I have been reading threads about peoples auto transmissions on df. Its not a secrete that these tranny's are prone to failure.
anyways, I was coasting to a stop when I saw traffic ahead on the highway the other day, and went by a large concrete wall on the driver side. the combination of coasting(exhaust quieter) and the large hard surface of the wall allowed me to hear a clicking tapping noise that I hadn't been aware of.
Later after I got home I put the rear axle on jack stands and put in in neutral so I could rotate the drive shaft to listen to my diff, U joints and transfer case only to discover that the clicking/tapping noise is being generated somewhere between the transmission and the transfer case. It just sounds like a metal on metal tap. not super loud but very obvious. and the shaft rotates without abnormal resistance (I think)
thats about all I know at this moment. I figure that it's probably on its way to being destroyed soon like everyone Else's.
anyone have a shot in the dark estimate of how long you think I have to save up a few grand to throw at it?
Thanks in advance
Old Sep 23, 2011 | 06:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I suppose it would not hurt to remove the tail shaft and inspect the snap ring. http://www.drivetrain.com/parts_cata...ase_saver.html
Old Sep 23, 2011 | 10:45 PM
madmax0r's Avatar
madmax0r
interesting, Ill have to tear into it. even if its the trany is going out I might as well take care of the little snap ring problem reguardless
Old Sep 23, 2011 | 10:47 PM
MonteC's Avatar
MonteC
what year is the truck?
madmax0r's Avatar
madmax0r
thanks btw, im surprised that 100 people have viewed this and nobody has any ideas
Its a 2001
Old Sep 23, 2011 | 10:48 PM
zman17's Avatar
zman17
You been drinking again Monte?
Old Sep 23, 2011 | 11:02 PM
CPTAFW163's Avatar
CPTAFW163
Its a 2001
Easy there young buck. You had a response from MonteC...he is a transmission expert and has a shop that specializes in our transmissions. He is the only person that needs to respond.
Old Sep 23, 2011 | 11:12 PM
madmax0r's Avatar
madmax0r
I wasn't being ungrateful, I just figured it might be a common problem... just a bit surprised.
Im extremely grateful for everyone's time and help
Old Sep 24, 2011 | 12:09 AM
rocky_mtn_ram's Avatar
rocky_mtn_ram
Mine was doing the same thing. I heard it on the drive thru brick wall at dairy queen one night. Turned out to be in the overdrive. The snap ring that holds the o/d direct clutch pack. So its rebuilt now...I'm writing a diy on it now actually.
Old Sep 24, 2011 | 01:28 AM
master tech's Avatar
master tech
Site Moderator & Tech
MonteC respond with a valid question in post #4, Because the 2gen is from 1994 to 2001. MonteC is one of the best transmission person I have seen posting. Since you have verify the sound that the transmision is making and I think you said you Isolate the area. Have you drop the pan yet and check for debris? Not everything in these transmission is a common problem. The only thing that is common on the 2001 truck and only on the 2001, to remove the transmission. You need to drop the exhaust.
