sludgy coolant leaking somewhere on front of engine.
Old Sep 24, 2011 | 04:57 PM
trae08's Avatar
trae08
Default sludgy coolant leaking somewhere on front of engine.
I noticed this a few days ago and have been curious as to what the problem is. my oil comes out clean if that makes any difference. its right behind my alternator. I had to take my alternator off to get some of the pictures. Check out the pics below.
if you can tell what the problem is could you tell me if its something i could fix myself or if i need to take it in to have it fixed. and what it would cost.
Heres a link to the album there are 6 images.
on the last image its unrelated to this problem i was just wondering if that corrosion was normal. And if not what do i do to fix it.
http://imageshack.us/g/215/dsc03372o.jpg/
Old Sep 24, 2011 | 05:01 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Looks like the thermostat housing or the by pass hose is leaking.
Old Sep 24, 2011 | 06:19 PM
UnregisteredUser's Avatar
UnregisteredUser
My vote's on the bypass hose. That said, were it mine to do, I'd replace the water pump and the bypass hose just because I'd be digging that deep.
Old Sep 24, 2011 | 07:40 PM
redneck_ram's Avatar
redneck_ram
haha water pump haha good times, brand new gmb pump on my truck as of yesterday and its already pissing everywhere.
Old Sep 24, 2011 | 09:27 PM
Ramzy's Avatar
Ramzy
Just had to replace that little joy (Sarcasm intended) of a hose on mine today.
Old Sep 24, 2011 | 09:42 PM
trae08's Avatar
trae08
So the bypass hose is that black hose in one of the pictures correct? Also why would it be so sludgy and not liquid?
Old Sep 24, 2011 | 10:34 PM
Ramzy's Avatar
Ramzy
Mixing with oil and dirt if your valve covers have any leaks or the intake manifold has oil residue on it, or any number of reasons. As long as the coolant in your system doesn't look like that.
Old Sep 24, 2011 | 11:00 PM
trae08's Avatar
trae08
Alright. so can you show me what the bypass hose looks like? i looked at the autopart store website and it showed 2 of them. i guess there is one thats in the water pump?
leaking valve covers. is that something i should be concerned about?
Old Sep 24, 2011 | 11:05 PM
Any leak should be addressed. Valve covers might be as easy as tightening the bolts.....
The hose is only about 3 inches long, with a slight bend to it. Goes from the water pump, to the intake manifold. It hides under the A/C compressor, and bracket, so, it isn't easy to see......
Old Sep 24, 2011 | 11:15 PM
merc225hp's Avatar
merc225hp
This is what one looks like.
Part Link http://www.rockauto.com/catalog/raframecatalog.php
