ignition issues, need thoughts and ideas!
Old Sep 26, 2011 | 12:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can try heat, but that will most likely ruin the o2. Although it's probably no good anyway.
Old Sep 26, 2011 | 12:54 PM
autolockguy13's Avatar
autolockguy13
only heat i have is propane, i dont think it will get it hot enough, especially with the breeze right now
Old Sep 26, 2011 | 01:06 PM
zman17's Avatar
zman17
Did you go by this, and trace each wire from cap to the plug?
Old Sep 26, 2011 | 01:19 PM
merc225hp's Avatar
merc225hp
Have you checked to see if the rotor is in fact at/on cyld 1 on the cap with the motor at tdc comp stroke?
Old Sep 26, 2011 | 01:21 PM
autolockguy13
yes, i went by that and ive traced and re-traced 3-4 times now. im as we speak here trying to wire in the obd2 data plug so i can read codes. hey you was saying it could be arcing in the wires, they are less than a yr old and are just cheapy oreilly brand. i really dont have money to throw at this truck anymore but i could go get new cap rotor and wires again if it fixes the problem. my problem is if i spend the 60 bucks and it doesnt fix it then im out that money too.
unplug coil and it cranks as should, plugged in and it cranks 2-3 revolutions and then really dies down and voltage drops to about 8.5v...
Old Sep 26, 2011 | 01:24 PM
autolockguy13
i havent checked the rotor against the engine, but i didnt completely remove the distributor or even loosen the nut, nor did i do anything with the timing chain and it ran before so i going under the assumption that the distributor has to be in sync
Old Sep 26, 2011 | 01:29 PM
Might not be a bad idea to have a look, just to eliminate it as a possibility........
zman17's Avatar
zman17
I'd try and get the o2 out first. If that doesn't help, I would replace the cam sensor before replacing cap rotor and wires.
Old Sep 26, 2011 | 01:31 PM
autolockguy13
i did replace the cam sensor with no luck
this is going to sound stupid, whats the best way to find #1 tdc on compression?
Old Sep 26, 2011 | 01:32 PM
zman17's Avatar
zman17
Oh, I thought you replaced the crank sensor.
