starting problem..
Old Sep 26, 2011 | 05:37 PM
drtbker13's Avatar
drtbker13
Default starting problem..
so like 3 weeks ago my truck wouldnt turn over everytime i turned it all it would do is click once then stop and i had to turn at least 3 times then it would start sometimes it would turn really fast then start. so i got a new battery cause my batter has been stock from when the truck was brand new so after i did that i changed the negitive battery terminal and it started just find but it happened again the other day and its been doing it for 2 days or so. i need help asap
Old Sep 26, 2011 | 05:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Wow, start off with some punctuation and grammar. Then check all the cables on the battery and especially the positive running down to the starter. Then bring it to autozone or where ever and let them check the charging system.
Old Sep 26, 2011 | 05:56 PM
drtbker13's Avatar
drtbker13
Here i will fix that for you. But i already had all that checked and it came back fine. Only sometimes it starts the clicking then sometimes it just turns over and starts.
Old Sep 26, 2011 | 06:04 PM
zman17's Avatar
zman17
So you checked all the connections and removed the starter to have it checked out right?
Old Sep 26, 2011 | 06:08 PM
drtbker13's Avatar
drtbker13
Yes. When i took it to autozone they told me when i replace the terminal check the line for rust. But i did not see any.
Old Sep 26, 2011 | 06:21 PM
zman17's Avatar
zman17
Just because you don't see anything, doesn't mean there is not a bad connection. You need to remove the wires/connections and clean them all. Then reconnect.
Old Sep 26, 2011 | 06:23 PM
drtbker13's Avatar
drtbker13
Would it be wise to just replace the wiring? My truck has 150,000 miles on it.
Old Sep 26, 2011 | 06:30 PM
zman17's Avatar
zman17
Wise maybe to replace, but a lot cheaper to clean them first.
Old Sep 26, 2011 | 06:44 PM
drtbker13's Avatar
drtbker13
I cleaned most of it the yesterday to see if it was the cause but this morning it still had the problem.
Old Sep 26, 2011 | 07:30 PM
John D in CT's Avatar
John D in CT
"Wow, start off with some punctuation and grammar".
I find it odd that punctation and grammar could keep a truck from starting, but I guess I've seen stranger things ....
Hey, regardless of what the boys down at Autozone think, it sounds very much like your starter is bad; specifically, the solenoid drive. The symptoms fit that perfectly.
Sometimes a starter can seem OK when you hit it with 12 volts on a bench, but not get the job done when it's in the vehicle.
I'm lucky to have a father-and-son auto electric shop 1/4 mile away from my shop that does nothing but rebuild starters and alternators in-house. They test my stuff, and even let me take a starter, alternator or battery if we're not positive what's defective, and bring back whatever I don't need. If Autozone won't do that for you, try to find someone who will.
Good luck, and please let me know if it was in fact the starter.
