double roller timing set
Old Sep 29, 2011 | 08:36 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Old Sep 29, 2011 | 08:41 PM
gdstock's Avatar
gdstock
Just received my timing set with tensioner from Mopar Performance yesterday. Hope to install this weekend.
Even got Mopar Performance decals - those should boost mpg by 5% or so, huh?
And in case someone may be wondering what double roller chain is, here is a photo:
Old Sep 29, 2011 | 09:07 PM
J415's Avatar
J415
Getting ready to do my timing chain (I also got Comp #2103 from amazon) and I'm wondering, is it really recommended to put a tensioner on. Aren't the timing chains switched out every 100k-150k? If a tensioner was installed, how much longer could you run a timing chain?
Old Sep 29, 2011 | 09:10 PM
Tensioner won't make it last any longer. what it will do though, is dampen a bit of the bounciness in your ignition timing...... it also allows you to run a sloppy chain longer, with less danger of jumping teeth......
I didn't install one when I did my timing set. It's nice to have, but, I don't really believe its a requirement.
lastrights's Avatar
lastrights
i need to do mine too
let me know how she feel after
Old Sep 29, 2011 | 11:39 PM
BackwoodsRam's Avatar
BackwoodsRam
will do and im not gonna be installing the tensioner if it doesnt really help out very much
Old Sep 30, 2011 | 08:31 AM
Adobedude's Avatar
Adobedude
Talking
Originally Posted by jasonw
Not really recommended. I'd leave it at stock, and if you want timing adjusted, get a SCT.
I think your confusing valve timing and ignition timing.
Old Sep 30, 2011 | 07:49 PM
BackwoodsRam
any tips on replacing the timing set and water pump? im gonna leave the clutch fan attached to the old water pump and just unbolt the old pump since im going with an efan set up. any input is appriciated
Old Sep 30, 2011 | 08:18 PM
Gotta take the fan and shroud at the same time, doing fan/shroud/water pump might be tricky. Try and unscrew the fan, if it want's to be difficult, screw it, leave it on the pump.
Dont forget the two bolts coming up from the bottom that hold the timing cover to the oil pan. Also, be careful when removing it you don't tear that gasket.
Line up the marks on the crank/cam gears BEFORE you take any bolts off.
Old Sep 30, 2011 | 08:24 PM
BackwoodsRam
will it screw up timing or or something if i dont, jw?
