Axle hop?
Old Sep 30, 2011 | 04:37 AM
peshewa's Avatar
peshewa
Default Axle hop?
Okay folks, I am perplexed here. I bought a low miles but highly abused 2001 ram 1500 about 10 days ago. It has 3.9 auto & is 2wd. The rear tires I notice have intermittent small chunks missing. The problem - When I start to go form a stop, especially after it is warmed up, it shakes violently, then starts to smooth out after it makes a groaning noise, then is fine at speed. I noticed the rear tranny mount looked worn out, so I replaced it today & it still does it. I peeked in the rear diff filler hole & it has plenty of fluid, but it smells like sin. The u-joints seem fine. I checked those with it in neutral on level ground, zero play there no matter how I twisted or moved them. The shaft over all has about 1.5 inches of rotational play. I wonder if a worn shock can do this? The tranny shifts okay as far as I can tell. I could not get proper recall info from all data as they seem to charge for the full scoop now. I have not removed the diff cover completely yet, I am apprehensive to do it since I am too broke to buy new fluid & gasket for now. There is some body damage because the previous owner considered putting it in a demo derby, got drunk & the front driver's door & fender & headlights are far less than perfect. It only has 42k miles, so I figured it is worth the risk. I just want to find it to be simple & cheap to fix. Any help you can give would be appreciated.
Old Sep 30, 2011 | 08:09 AM
Sheriff420's Avatar
Sheriff420
Could be worn out shocks. Where does the groaning noise come from?
Old Sep 30, 2011 | 08:55 AM
Need to find out why it is shaking..... What do your brakes sound like? Also may want to drop the rear drive shaft, and see if your u-joints are binding.....
Old Sep 30, 2011 | 03:46 PM
peshewa's Avatar
peshewa
Okay, the tranny shop said the forward clutches are shot, that is causing all the issues. Thanks for reading folks. I did check for recalls, there are none for this issue but it is strange that the salvage yards said they cant keep the 518 tranny in stock & they assume they are problematic. I am going to save $1300 for a proper rebuild from my tranny guy. Wish me luck!
Old Sep 30, 2011 | 03:52 PM
jasonw's Avatar
jasonw
Site Moderator
If your transmission guy says you have a A518, find a new transmission guy. I hope that was just an off hand (and partially wrong) comment from the salvage yard.
The A518, also known as a 46RH/46RE, was only in the V8s. The V6s all had the A500, or 42RH/42RE.
Either way though, his comment about them being problematic is more or less correct. If properly taken care of, they will last a very long time, but abuse them at all, even a little, and they tend to fail pretty quick.
EDIT: https://dodgeforum.com/forum/2nd-gen...do-i-have.html
Old Oct 1, 2011 | 03:38 AM
peshewa's Avatar
peshewa
Thanks for the heads up on the tranny model. I even looked on ebay & they displayed 518's that were listed for a v8 or v6, elegedly dependant upon application. Interesting indeed.
Old Oct 1, 2011 | 05:22 AM
97tn4x4's Avatar
97tn4x4
There's nothing say you can't put the 46re in yours though.
Old Oct 2, 2011 | 11:53 PM
peshewa's Avatar
peshewa
Okay then guys, can any of you tell me exactly how to tell which tranny I have so I can find a junk yard replacement?
Old Oct 3, 2011 | 08:58 AM
42re.
