Wet Passenger Floorboard
Old Sep 30, 2011 | 07:49 AM
stewie01's Avatar
stewie01
Default Wet Passenger Floorboard
I've noticed the "disappearing" engine coolant for a little while now along with the "gurgle" noise in the dash on some start ups.
And my passenger floorboard usually gets pretty wet after I re-fill the coolant tank (just using some water for now while it's leaking)
Does this sound like a bad heater coil? How much of a PITA is the job normally?
Thanks.
Old Sep 30, 2011 | 08:00 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I have to go to work, so no time to explain find everything for you. Go to FAQ/DIY and look. Also do a search here on DF for the heater core topic. There are 100's of threads. Cya later
Old Sep 30, 2011 | 08:05 AM
stewie01's Avatar
stewie01
Well have a good day at work!! I'm on Vacation till next Thursday!
Old Sep 30, 2011 | 08:56 AM
Sounds a lot like the heater core to me......
Old Sep 30, 2011 | 09:10 AM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by stewie01
IDoes this sound like a bad heater coil? How much of a PITA is the job normally?
Yep, sounds just like a leaking heater core, and the job is a massive PITA. You've got to pull the dash to get at it.
Old Sep 30, 2011 | 09:29 AM
SilverSS's Avatar
SilverSS
Does the carpet smell like antifreeze?
Old Sep 30, 2011 | 10:15 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Could be the passenger window wasn't raised all the way and it rained inside of your truck.
The disappearing coolant is merely a coincidence.
Old Sep 30, 2011 | 10:18 AM
COW III's Avatar
COW III
Yes, those are classic symptoms of a bad heater core. The DIY section has a nice step by step. It should take you 3 - 5 hours depending on how many breaks/beers you have. It is not that hard, just time consuming. Make sure the new heater core you get has pipes/lines that swivel. It makes reinstalling the new core MUCH easier.
Old Sep 30, 2011 | 10:23 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
I disagree. How could the heater core possibly be leaking onto the carpeting when it's buried in the dash?
The OP should drag this out for at least 5 pages by asking a litany of inane questions rather than taking the time to search through the DIY section
Old Sep 30, 2011 | 10:44 AM
COW III's Avatar
COW III
I guess it could possibly be that someone is playing a prank on him. Lowering the coolant level and pouring liquid on the passenger side floor.
Do you keep your doors locked at night?
