will 99 durango trans fit my 96 ram
I know they are probably different but will they bolt upp? any chance?
durango :99 5.2 318 4X4 vin 1B4HS28Y2XF561629
ram: 96, 4x4 5.9 360
basically i'm getting the whole durango for 300 and was hoping i could use this trans.
anyone know what else would fit? I need this in my truck,
axels, torque converter,
any of this compatable?
I don't think the axles will work.... different widths. (not even sure what axles they used in the Durango's......)
Trans will physically bolt up, but, some of the wiring for the sensors/solenoids changed, so, you would prolly have to find out exactly which ones, and replace them with the correct units.
Torque converter may also not work. There was a changover from using the flywheel (drive plate, whatever) as the balancing component, or the torque converter, not sure what year that changed.
