PCM swap
Old Oct 3, 2011 | 11:24 PM
  #31
gdstock's Avatar
gdstock
I think I would pop in a new injector and see what happens. What does an injector cost? What would be the rate of return IF that solved the problem?
Old Oct 4, 2011 | 11:58 AM
  #32
Swap 'em first. No cost test.... if the miss moves with the injector, it's bad, if the miss stays on number four, and everything else checks out, PCM. (My money is on the PCM at this point.)
Old Oct 4, 2011 | 12:15 PM
  #33
gdstock's Avatar
gdstock
+1 on swapping. Don't know why I always go for a new one ----mayme my propensity from breaking upon removal....?
Old Oct 4, 2011 | 01:16 PM
  #34
zman17's Avatar
zman17
Retired Moderator - RIP
Get at least 8 new orings before you do the swap. Or even if you get a new one.
Old Oct 4, 2011 | 07:29 PM
  #35
Mortimer's Avatar
Mortimer
Thank you everyone for your help.Today I took the PCM out of my 2500. and put it in the 1500.The P0204 code is now in the 1500.I need a PCM.Can anyone recommend a good company or website to get a PCM.I would like a little more performance.
Old Oct 4, 2011 | 08:19 PM
  #36
lastrights's Avatar
lastrights
can sean overwrite it ? or maybe go to the dodge dealer and see if they can write you a new one
Old Oct 4, 2011 | 08:24 PM
  #37
No, it's not a programming failure, its a hardware failure. He needs a new PCM.
Can get one from a junkyard, and then just take it to a shop/the dealer, to have it flashed for your VIN, and Mileage. (if applicable....) Stay away from Auto Computer Exchange, they suck. Parts store should be able to get one for ya. Dealer could too, but, they will want an arm, leg, first born male child, and half your soul...... Then they will ask about installation/flash updating......
Old Oct 4, 2011 | 08:45 PM
  #38
zman17's Avatar
zman17
Enough with the "leg " references already, jeez.
Old Oct 4, 2011 | 08:54 PM
  #39
BackwoodsRam's Avatar
BackwoodsRam
giggle
Old Oct 4, 2011 | 08:55 PM
  #40
Oh? Is that the REAL Story? You need a part only the dealer had?
