more problems... brakes this time
Old Oct 5, 2011 | 11:45 PM
autolockguy13's Avatar
autolockguy13
Default more problems... brakes this time
ok so i had a caliper that was hanging up. caused me to pull left whenever driving and when the clutch was pushed in it would stop me by itself. so i replaced both calipers, pads, and rotors and it still hung up on the drivers side... so i bought a hose and put it on... its a little better, doesnt pull to the left, but i can hear it whenever im moving and feel it dragging at lower speeds. what else could be causing this to happen?
thanks for the input
jesse
Old Oct 6, 2011 | 12:20 AM
merc225hp's Avatar
merc225hp
Were the new calipers loaded (new bolts and sleeves)? I copied this from the sm.
Metering Valve
Metering valve operation can be checked visually
and with the aid of a helper. Observe the metering
valve stem while a helper applies and releases the
brakes. If the valve is operating correctly, the stem
will extend slightly when the brakes are applied and
retract when the brakes are released. I f the valve is
faulty, replace the entire combination valve as an
assembly.
Old Oct 6, 2011 | 12:52 AM
autolockguy13
Whats a metering valve and wheres it located? Never heard of it before...
Old Oct 6, 2011 | 01:05 AM
merc225hp's Avatar
merc225hp
It should be just below the master cyld, it's also called a brake proportioning valve. I am trying to find an illustration for you.
Old Oct 6, 2011 | 08:42 AM
autolockguy13
prop valve i understand. i know what ur talking about now. ill look into it after work today
Old Oct 6, 2011 | 04:37 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It's doing this when you don't even have your foot on the brake?
Old Oct 6, 2011 | 07:35 PM
autolockguy13
Correct. I can jack up drivers side and spin the wheel but as soon as i stop, the wheel stops. As im driving down the road i can hear it dragging too
Old Oct 6, 2011 | 07:59 PM
zman17's Avatar
zman17
You sure it's not the hub bearing or ujoint?
Old Oct 6, 2011 | 09:38 PM
Jack up the front of the truck. Spin the wheels. See how they feel.
Step hard on the brakes.
Repeat step one. If either/both are sticking, crack open the bleeder valve. If that unsticks it, you still have a bad hose/line somewhere.
Old Oct 6, 2011 | 11:04 PM
autolockguy13
Last night when i loosened the bleeder it let the caliper loose. Hubs, u-joints are maybe 500 miles old... The truck is at my work right now, gunna dick with it tomorrow sometime...
