trans problem
Old Oct 9, 2011 | 11:50 AM
  #41
zman17's Avatar
zman17
Retired Moderator - RIP
Try photobucket, upload to PB and copy the image code on the drop down menu, and paste to you post here. Anyway, someone obviously bypassed the factory system.
Old Oct 9, 2011 | 12:01 PM
  #42
Shaun Hamilton's Avatar
Shaun Hamilton
I will do that. Would it hurt to hook factory back up and still run the aftermarket cooler?
Old Oct 9, 2011 | 12:12 PM
  #43
Files have to be jpeg format, or similar. (no .bmp files...) Upload them to someplace like photobucket, and then just use image tags to put them in a post.
Old Oct 9, 2011 | 12:22 PM
  #44
Shaun Hamilton
http://s1181.photobucket.com/albums/...notherlawnguy/
Old Oct 9, 2011 | 12:23 PM
  #45
Shaun Hamilton
hope that works
Old Oct 9, 2011 | 12:32 PM
  #46
zman17's Avatar
zman17
Put your mouse cursor on the pic. A little window will open. Click on the IMG code. When you do that, you'll see it say copied. Then come here and paste.
And take more pics following the lines. I want to see the cooler you are talking about. And do the lines go in between the front of the rad and the ac condenser?
Old Oct 9, 2011 | 12:35 PM
  #47
Shaun Hamilton
Old Oct 9, 2011 | 12:36 PM
  #48
Shaun Hamilton
there we go. Thanks a lot
Old Oct 9, 2011 | 12:41 PM
  #49
gdstock's Avatar
gdstock
The previous owner may have bypassed the radiator cooling becasue there may have been a leak or other problem. Since the ports to the radiator ports are not plugged, I would not connect back to them without cleaning the radiator out very good.
Preferred (imho) would have been to install the aftermarket cooler between the upper radiator connection line and the radiator.
A lot of people add the aftermarket cooler to increase cooling capacity over the original design, expecially if truck will be used for towing or heavy load situations.
It looks like they also cut out the check valve.
Old Oct 9, 2011 | 12:44 PM
  #50
Shaun Hamilton
ok thanks. Ill leave it alone. I pull a 18' trailer with 3 tractors. gross weight about 4,200 ish
