Drive Shaft
Old Oct 6, 2011 | 08:21 PM
GregBranton's Avatar
GregBranton
Default Drive Shaft
I've got a question for you guys now. I was just backing into my driveway, knew my u-joint was getting bad. Put the truck in reverse, and pop, driveshaft in the driveway. The C shaped clips (I guess you can call them clips) with the bolts in them came loose and fell out. I would like to replace the driveshaft and yolk (assuming thats the proper name. Piece connected to the rear end) as the driveshaft has a few dings in it and the yolk is wore a little.
question is, will only a driveshaft from a 4X4 work? I know where I can get a 2wd shaft but i'm unsure it if will work. The truck is a 5spd standard (nv3500 I Believe)
Old Oct 6, 2011 | 08:37 PM
BackwoodsRam's Avatar
BackwoodsRam
2wd d-shaft will be longer than a 4wd
edit: can you also add if your truck is a 1500/2500/ etc to your sig. a lot of parts interchange but some dont
Old Oct 6, 2011 | 08:55 PM
GregBranton
Thanks for the reply. Truck is a 1500. I'll check the local scrap yard tomorrow, see whats kicking around. Any 4x4 d-shaft will fit?
Old Oct 6, 2011 | 09:09 PM
BigRedRam95's Avatar
BigRedRam95
is the shaft beat up so bad that you cant use it? I droped mine going down the interstate and still used it.
Old Oct 6, 2011 | 09:34 PM
Has to be from the same weight rating, same bed length, and same cab style as yours.
Old Oct 6, 2011 | 10:19 PM
BackwoodsRam
if its not beat up to bad a shop may be able to rebalance it for you
Old Oct 7, 2011 | 03:59 PM
Wombat Ranger's Avatar
Wombat Ranger
Or just the same length. If it fits it fits. Don't be scared to try what the yard has, just take yours in there (or measurements) and see whats up! Then post here when you find which ones interchange! So we can all learn from your experience!
EDIT: also not 100% sure but i think the club/quad cab sb's have the same wheelbase as reg cab lb's... I think.
