Reliable Valve Spring Compression Tool
Old Oct 8, 2011 | 06:09 PM
romadramowner's Avatar
romadramowner
Default Reliable Valve Spring Compression Tool
I am replacing my valve seals on my 5.9 Magnum and the tool I was using broke. It was a universal one from Summit Racing. If anybody has had luck with another one please pass the information.
Thanks,
Brandon
Old Oct 8, 2011 | 11:21 PM
I used the cool snap-on on-the-head valve spring compressor.... of course, being snap-on, its priced like its made out of friggin' gold......
Old Oct 9, 2011 | 08:36 AM
romadramowner
I may end up just fabricating one from spare metal. I'll share pics if it works. The number seven and eight cylinders are going to be a pain.
Old Oct 10, 2011 | 09:43 AM
Novarider's Avatar
Novarider
What about this one
http://www.harborfreight.com/univers...sor-92900.html
Old Oct 10, 2011 | 10:34 AM
romadramowner
Novarider,
That's exactly like the one that I broke yesterday. I ended up buying two from NAPA today. One is just a lever made of steel and the other is more of a crimp-style with a lever causing the compression. I'll let you know if either one sucks.
Old Oct 10, 2011 | 04:07 PM
romadramowner
Okay, I ended up using tools very similar to the ones in the pictures below. I found it made life easier if I were to tap with a hammer on the top of the valve spring caps (not the valve itself) just to pop them and the keepers loose. I then used the lever on the ones that were accessible and the other contraption on the ones under the firewall.
Anyway, I should have taken pictures of it but the valve seal replacement was pretty easy. Hopefully this fixes my oil consumption problem since I already have the Hughes plenum fix...
Old Oct 10, 2011 | 04:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1 on the tapping with a hammer. That's how I learned to break them free a 100 years ago.
Old Oct 10, 2011 | 04:30 PM
We probably learned that trick using the same rocks.
Old Oct 10, 2011 | 04:35 PM
zman17's Avatar
zman17
Old Oct 10, 2011 | 04:37 PM
romadramowner
They had cars back with you guys were kids??? jk
