bought some headers..
Old Oct 9, 2011 | 10:21 PM
71dodge's Avatar
71dodge
Default bought some headers..
need your opinion. just bought these off ebay for 122 shipped. i couldnt beat it. i was gonna put headers on the truck eventually anyways.. but wt do you think about these
http://cgi.ebay.com/ebaymotors/ws/eB...ht_5026wt_1026
Old Oct 9, 2011 | 10:29 PM
Ceramic coated? Wow..... Will be real curious to see how these hold up for ya. Wonder what size the outlets are..... Look like 2.5"...
If you still have the stock y-pipe though, you won't notice the full benefit of these. Y-pipe is the biggest restriction in the exhaust on these trucks.
Old Oct 9, 2011 | 10:33 PM
71dodge's Avatar
71dodge
yea thats why i bought them. i seen they were ceramic coated and was like damn lol. and its getting a full exhaust system next. the guy at the muffler shop told me to keep my stock y pipe though? i thought that was weird but he said it will make my check engine light come on if i dont
Old Oct 9, 2011 | 10:35 PM
71dodge's Avatar
71dodge
i also got a question. my dad seems to think that after i just put a double roller timing chain new water pump plenum plate n all this on it that i wont notice any diffrence in the truck.. oh and you friggin belive my plenum wasnt blown. SOB was still all in tact
Old Oct 9, 2011 | 10:45 PM
The guy at the exhaust shop isn't as well informed as he could be. You can do basically whatever you want to the exhaust, so long as there is still a cat between the front, and rear O2 sensors, you shouldn't get a CEL. If you do, the non-fouler trick solves it for a couple bucks. (and will work even if you 'forget' to put a cat back on.)
Have a look at the Jeg's Off-Road Y-Pipe. has provisions for both O2 sensors, and if you wanna stick a cat in there, just slice out a section of the pipe between the fittings, and put a magnaflow hi-flow cat in there.
If you do headers, y, and full exhaust all at once, you WILL notice a difference.
Old Oct 9, 2011 | 10:51 PM
71dodge's Avatar
71dodge
whats the non fouler trick?
Old Oct 9, 2011 | 10:54 PM
gdstock's Avatar
gdstock
There is a thread for the non-fouler in the DIY section. Looks pretty easy.
Old Oct 9, 2011 | 10:55 PM
There's an article in the FAQ section on 'em. Basically, they are spark plug non-foulers. A fitting you screw the spark plug into, that has a little hole in it, (combustion chamber side.) Ignites cylinder, but, has little exposure to all the crap in the cylinder.... so, pro-longs the life of spark plugs, at the cost of efficient spark propagation. They are a bandaid fix for a motor that needs rebuilt really......
If you buy two, drill one all the way out, screw that one into a non-modified one, screw those into the O2 fitting, then screw the O2 sensor into the non-fouler..... the sensor is partially shielded from the exhaust flow, so, it will read like it is downstream from a cat. Even if there isn't one.......
Old Oct 9, 2011 | 10:58 PM
gdstock's Avatar
gdstock
Yeah....there. I was being a little lazy and lethargic - Ranger game postponed today...
