Funny squeaking/wobbling noise when driving...
Old Oct 10, 2011 | 03:25 AM
Jeffress77's Avatar
Jeffress77
Default Funny squeaking/wobbling noise when driving...
I noticed in the past few days...there is a funny squeaking/wobbling noise that sounds like it is just outside the firewall somewhere (I could be wrong), when I am at lower RPM/lower speed. Kinda like a medium pitched "whoop whoop whoop" every second or so off and on.
I can somewhat feel the vibration of the noise on the steering column sometimes. This ONLY OCCURS when the truck is in gear and also in motion. I tried shifting into neutral at approx. 20-30 mph and the sound stopped. Once I shifted into drive the sound started again. The noise is either faster, softer, or less audible at higher speeds (excess of 40 mph) and seems to be more deliberate at lower speeds.
The sound is not there always, but probably 50% of the time I am driving. It started maybe a week ago, and has gotten a bit louder/more frequent in the past two days.
Any ideas? I really don't know where to start since I can't listen for it or check for it unless the truck is rolling, and in drive.
Old Oct 10, 2011 | 08:34 AM
Check and make sure the CAD on the front axle is disengaging completely.
Old Oct 10, 2011 | 10:27 AM
Jeffress77's Avatar
Jeffress77
Stupid question...Does the 2WD model have a CAD system? I have a 2WD not 4x4.
Old Oct 10, 2011 | 10:32 AM
zman17's Avatar
zman17
Retired Moderator - RIP
No CAD on a 2wd. He must be drunk again.
Old Oct 11, 2011 | 12:14 AM
Jeffress77's Avatar
Jeffress77
To the top...
Old Oct 11, 2011 | 12:51 AM
gdstock's Avatar
gdstock
I wondered how HeyYou missed that one. That explains it - and early too!
Old Oct 11, 2011 | 07:14 AM
dhvaughan's Avatar
dhvaughan
i think the 01 2wd uses the same unit-bearing setup as the 4wd.
so grab the top of the tire and push/pull in and out with all your might. there should be no movement.
Old Oct 11, 2011 | 10:08 AM
Sheriff420's Avatar
Sheriff420
I have the same noise and it's been there for years. It sounds like I'm smuggling pigeons in front of the dash.
I can only hear mine below about 10mph and after a drive while the truck is stopped as long as it's in gear but only for a few seconds.
Motor mounts is my guess but I haven't gotten around to checking them out.
Old Oct 11, 2011 | 10:19 AM
Jeffress77's Avatar
Jeffress77
This is exactly the noise...
Old Oct 11, 2011 | 10:36 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I have a squeek noise when turning at around 15mph.
Usually when turning left though. It's weird.
