tailgate latch not releasing.. any help on this??
Old Oct 10, 2011 | 08:19 PM
TBI IRRIGATION's Avatar
TBI IRRIGATION
Default tailgate latch not releasing.. any help on this??
2001 ram 2500. how do i get the latch to operate again guys?? is there an adjustment?? thnx
Old Oct 10, 2011 | 08:30 PM
Did the handle break? Should be a panel on the inside of the tailgate you can take off, and manually pull the rods that operate the latches.
Old Oct 10, 2011 | 08:47 PM
crazzywolfie's Avatar
crazzywolfie
i don't know if they are the same anymore but on my 81 and 91 they have plastic clips the hold the rods into the mechanism. if the plastic clips break the rods can fall out.
Old Oct 11, 2011 | 12:49 AM
99dodge318's Avatar
99dodge318
Is there an adjustment for that latch? My tailgates a little difficult to open
Old Oct 11, 2011 | 12:58 AM
gdstock's Avatar
gdstock
I am thinking it may need grease at the operator as shown in the photoabove and at the strike latch. Don't think there is an adjustment, or it doesn't appear to show one in the FSM.
Old Oct 11, 2011 | 12:10 PM
crazzywolfie
there was not any adjustments on my truck but you could put a bit of a curve in the rods to make the latch more responsive. as shown in the picture above all that holds the rods in is a plastic clip. when they are broke there is nothing to stop the rod from falling out just like in the picture above.
this place seems to have clips that look like they would work but you may want to do some measuring before you order.
http://www.clipsandfasteners.com/Cli...ch=%20chrysler
or you could repair it the cheap way
Old Oct 11, 2011 | 01:20 PM
8uzzsaw's Avatar
8uzzsaw
I had an issue with my tailgate not opening. Once I got it open, I greased up everything that moved. Works great now. Maybe try that before you try bending anything (risking breaking the plastic clips maybe?)
Old Jan 3, 2013 | 10:38 PM
Jeff Hon's Avatar
Jeff Hon
My 99 Ram 1500 tailgate has no access panel. Inspection by removing the retaining bolts for the handle and the latches revealed the plastic clips holding the rods in place were intact, yet the right side would not release with the handle. The simple solution I used was to add a washer under each of the mounting bolts on that right side latch on the tailgate. Working fine now.
Old Jan 3, 2013 | 11:02 PM
Ham Bone's Avatar
Ham Bone
WD-40 fixed all my problems.
Old Jan 3, 2013 | 11:22 PM
crazzywolfie
you won't find wd-40 in my tool box. so far so good with my tailgate. that small piece of stainless steel wire is still holding on and working good.
