where to mount CB radio?
Old 10-13-2011, 02:00 AM
kd5taa's Avatar
kd5taa
kd5taa is offline
Here's a pic of my 2m/440. This would be a great place for a CB but I dont know if they make them with remote faceplates like they do for ham radios...
I ran my antenna wire through a small hole I drilled under the kickplate by the back seat
  #32
Old 10-13-2011, 02:38 AM
2000ramsport's Avatar
2000ramsport
2000ramsport is offline
ugly1 do you know the name of that front of seat bracket?this is what I want to mount my radio too.But I have no cb shop here so I will search the internet for one would love to see a pic of yours if possible .And kd5 my cb is to big to fit in that spot but that is a nice place for a radio if i could find a very small cb radio.thanks
  #33
Old 10-13-2011, 09:43 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
Originally Posted by Wh1t3NuKle
Could you guys kindly post pics of that location for the cb?
Originally Posted by kadetklapp
Ya that's my two-meter rig, but my CB (Cobra 29LCD) is on the floor in front of the console section of the bench.
SO is that a no kadetklapp?
Originally Posted by TitanOneSeven
I mounted my cb is the same place as a few other people on here, I find its placement works well since it is out of the way but still withing reach, and being at the bottom edge of the dash allows the wires to be hid quite well.
As for the cable as was asked before. I ran mine through the rubber grommet that's at the back lower corner of the cab. And then ran the cable under the door still and up under the dash to the radio, no tight bends and a short cable length.
Here is a pic of the spot I'm talking about with the hole in the cab corner. Not sure if the standard cabs have it too or just the extended.
TitanOneSeven -- Much appreciated on the pictures and description. That helps a ton!!
What is under your CB? Inverter?
As for the bracket, I think people might be talking about this one, however I've not a picture of it installed.
http://www.genosgarage.com/prodinfo.asp?number=WD_CB1
How come no one has used the ashtray? Located closest to the dummy pedal.
  #34
Old 10-13-2011, 10:31 AM
TitanOneSeven's Avatar
TitanOneSeven
TitanOneSeven is offline
You are correct sir. Its a 400w inverter, also by Cobra, and I find it comes in handy very often. And you are welcome for the pictures.
  #35
Old 10-13-2011, 10:58 AM
kadetklapp's Avatar
kadetklapp
kadetklapp is offline
Sorry, didn't see your comment. I might have a picture on my phone I'll look when I get in the office.
  #36
Old 10-13-2011, 11:11 AM
Ugly1's Avatar
Ugly1
Ugly1 is offline
The one I have is like the U-bracket mounts on this page. http://www.kenselectronics.com/lists/cbmount.htm
  #37
Old 10-13-2011, 02:36 PM
2000ramsport
thanks for the info guys ok my trucks a sport and it says something about not fitting sport modles.hmmm
Quick Reply: where to mount CB radio?
