Please help
Old Oct 12, 2011 | 06:20 PM
  #31
71dodge's Avatar
71dodge
that should solve my problem right?
Old Oct 12, 2011 | 06:24 PM
  #32
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by 71dodge
exactly valves are not opening when they should. so im going to tear it apart (again) andpull the valve cover off find TDC on #1 piston. pull the cap find TDC on the rotor put the chain back on and reinstall. after this i dont know what the hell it could be
You don't have to pull the TC cover off again to verify TDC. Just the valve cover and the dist. cap.
Old Oct 12, 2011 | 06:25 PM
  #33
71dodge's Avatar
71dodge
then it should line up on that mark on the harmonic balencer and it should be straight on with the TC cover right?
Old Oct 12, 2011 | 06:54 PM
  #34
71dodge's Avatar
71dodge
timing is way off when cyl #1 is TDC the rotor is sidways. not straight up n down
  #35
71dodge's Avatar
71dodge
so that means i have to adj the cam gear only right?
Old Oct 12, 2011 | 06:58 PM
  #36
zman17's Avatar
zman17
No, that means you have to do what I suggested/provided links for to begin with.
Old Oct 12, 2011 | 07:38 PM
  #37
Rammified_99's Avatar
Rammified_99
come on anybody? i need to know how to fix it.. and would the timing throw it off? i had it top dead center is that wrong
Hello, where was your original problem / issue?
If ya didn't get it fixed.
Worked on Dode trucks for 15 years if I can help?
Old Oct 12, 2011 | 07:56 PM
  #38
BackwoodsRam's Avatar
BackwoodsRam
read the all the pages of the thread and you will see what the issue was
  #39
zman17's Avatar
zman17
His problem is, that he rotated the cam and crank, when doing a simple timing chain and gear swap. just my opinion though. If I'm wrong, I apologize in advance.
Old Oct 12, 2011 | 11:02 PM
  #40
71dodge's Avatar
71dodge
well it didnt work. now what
