Head lamp problem,. help if you would,.??
Old Oct 13, 2011 | 04:20 PM
pradke's Avatar
pradke
Default Head lamp problem,. help if you would,.??
ok,.. Is there any one that would maybe help me out,..?? I have an 11 of 2000 dodge ram 2500,.. may right hand low beam went out,..I really didn't think much of it,.. but then the high beam also went out,. ( on the right side only),.. well,. I changed the bulbs,..still no head light on the right side,.( yes the left side works,.High and low ),. so I checked the power,.( fuse ).that I do have ,.but there is no ground signal being sent for the high or low,..
I know I can jump off the right side to correct the problem ,.but I would rather try and fix it correctly at the source of the problem,.. any help would be great THANK YOU,.. if nothing else,.??? does anyone have a head lamp wiring diagram for a 200 2001 ram,.???? THANKS AGAIN,..!!!!
Old Oct 13, 2011 | 06:15 PM
I think the headlight switch provides ground path..... there is an 01 service manual available for download in the FAQ section. Grab that, it has wiring diagrams that will make your life a LOT easier.
Old Oct 13, 2011 | 07:57 PM
redneck_ram's Avatar
redneck_ram
check the lens for water. i was having the same problem. ive gone through 3 bulbs so far and couldnt figure out why until i noticed water floating and splashing inside the headlight one night causing my bulb to blow.
Old Oct 17, 2011 | 07:19 AM
pradke's Avatar
pradke
thank you,..!!! I appreciate your help,..!!!
