Water in oil
Old Oct 13, 2011 | 04:59 PM
rscst's Avatar
rscst
Default Water in oil
I have a 96 dodge 2500 with a 5.9 gas engine. I was getting water in the oil so I jerked the heads off and discovered it had 3 cracks in one head and 2 in the other. I ordered new heads from Odessa cylinder heads put it back together and 3 days I check the oil and I got water in it again. I then removed the intake, thinking maybe the gasket slipped or something but couldn't find anything that would lead me to be believe water was leaking by. I stumped and can't figure this thing out unless the block is cracked and I missed it. Is there any other way water can get into the crank case.
Thanks Rodney
Old Oct 13, 2011 | 05:27 PM
merc225hp's Avatar
merc225hp
One possibility is the timing chain cover gaskets.
Old Oct 13, 2011 | 11:17 PM
Hahns5.2's Avatar
Hahns5.2
How much water? Small traces of "snot" or larger amounts?
Old Oct 13, 2011 | 11:31 PM
rscst's Avatar
rscst
large amount of water in the oil
Old Oct 13, 2011 | 11:40 PM
DamnDodgeRam's Avatar
DamnDodgeRam
Could be your Timing Chain gasket
Old Oct 14, 2011 | 06:56 AM
Novarider's Avatar
Novarider
Doesn't antifreeze destroy bearings?
Old Oct 14, 2011 | 11:59 AM
rumble_truck's Avatar
rumble_truck
Yes.. ask my 318 how it likes the slight knock at idle after spilling coolant in my valley during plenum fix
Old Oct 14, 2011 | 02:40 PM
kadetklapp's Avatar
kadetklapp
Not being a smart ***, but you did change the oil after installing the new heads, right?
