sloppy steering
Old Oct 19, 2011 | 12:34 PM
  #21
wallz55's Avatar
wallz55
did you check the track bar on the front axle I have replace 3 of them on my truck
Old Oct 19, 2011 | 01:44 PM
  #22
gman13514's Avatar
gman13514
The truck came with 265/70/16 I put on 275/70/17. The rims are dodge rims but the tires i got from a friend of mine. They are only 1/2 worn,( he went to 31s) so quite possibly it is the tires. I'll have the guy at the alignment shop check it out. thanks for all the help!
Old Oct 19, 2011 | 02:01 PM
  #23
John D in CT's Avatar
John D in CT
" .. the tires i got from a friend of mine. They are only 1/2 worn,( he went to 31s) so quite possibly it is the tires ... "
Had a feeling they were used. I have a 90% hunch they're your problem. The other 10% says maybe an alignment will help, if your old tires were worn to compensate for misalignment, and these tires aren't. Either way, an alignment can't hurt.
Old Oct 20, 2011 | 09:53 AM
  #24
publicricehater's Avatar
publicricehater
I have had a similar problem with my 97. I'll bet your steering gear box is worn out. That's what is wrong with mine. I am just to much of a tight as to replace it. lol
Old Oct 20, 2011 | 10:09 AM
  #25
There are some adjustments you can do to get a bit more life out of the old box. There is even a DIY in the faq section for it. Or, download the factory service manual (also in the faq section) and the procedure is outlined in there as well.
Old Nov 9, 2011 | 10:25 PM
  #26
Augiedoggy's Avatar
Augiedoggy
I thought the same thing...I even bought the steering arm bracket to stiffen things up and replaced a sloppy steering shaft with an adjustable heavy duty one because of my body lift.. While it helped I found the wander was still there....I just discovered play in my track bar the other day that I somehow missed the last time I looked for it so thats the next thing on my list..
