96 Dodge Ram wont shift from 2H to 4H
Old Oct 20, 2011 | 08:13 PM
reconrey's Avatar
reconrey
Default 96 Dodge Ram wont shift from 2H to 4H
It will shift from 2H to 4L, and 4L to 4H, but not 2H to 4H. Thanks.
Old Oct 20, 2011 | 08:18 PM
Erm, what isn't happening? The shift pattern is 2H, 4H, N, 4L... If you pull the stick back one notch, T-case should be engaged. Is it just the 4x4 lite isn't coming on?
Old Oct 20, 2011 | 08:21 PM
reconrey's Avatar
reconrey
No, the 4x4 light is coming on - its just its not in 4 wheel drive.
How are you determining that?
And by the way, Welcome to DF.
Old Oct 20, 2011 | 08:25 PM
reconrey's Avatar
reconrey
Well I tried turning on pavement after it didn't feel like they were griping in the dirt, and it turned just like 2 wheel drive. And then I went from 2H to 4L and it worked, then went from 4L to 4H and it was still 4wd, and I heard it shift - I don't even hear it changing from 2H to 4H.
Thanks!
Old Oct 20, 2011 | 08:28 PM
chadhager03's Avatar
chadhager03
Put it on jack stands and test it out, its a whole lot easier than gunning it in mud (but the second option is more fun if you got someone to pull you out )
Old Oct 20, 2011 | 08:37 PM
reconrey's Avatar
reconrey
Yea, I had tested it - and its not in 4wd. Thanks.
Old Oct 23, 2011 | 12:10 PM
Wombat Ranger's Avatar
Wombat Ranger
are your driveshafts turning when it has this issue? if so, get rid of that garbage factory vacuum CAD and get a cable operated one.
Old Oct 23, 2011 | 12:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The factory vacuum system is fine for a normally driven vehicle. I had the Posi-Lok on my 98. Just one more thing to do. (and not forget to undo). Fixing the vac setup is rather easy. http://www.dodgeram.org/tech/repair/..._engagment.htm
