Thinking about buying a 2001 2500
Old Oct 24, 2011 | 06:40 PM
exmoore's Avatar
exmoore
Default Thinking about buying a 2001 2500
Thinking about buying a 2001 2500 4wd extended cab Ram. Soon. Anyone have anything bad to say? Anything I should be aware of or look out for?
thanks.
Erik
Old Oct 24, 2011 | 06:48 PM
jdh0921's Avatar
jdh0921
One item that constantly comes up is about the plenum. Check out this thread :
https://dodgeforum.com/forum/2nd-gen...um-thread.html
I just bought one myself, haven't had anything really unusual happen to it so far, I like it.
Old Oct 24, 2011 | 06:56 PM
Wow, you beat zman to the punchline here. I'm impressed.
Welcome to DF! Both of you.
Old Oct 24, 2011 | 07:30 PM
BackwoodsRam's Avatar
BackwoodsRam
welcome,
-since you have a 4x4 if you do any front wheel hub maintence, be very careful, the front axle seal are very easy to screw up.
-+1 on the plenum, and if yours needs replaced then go ahead and replace the timing set and water pump, only go to a 180 degree t-stat if you get an SCT tuner
-a good tuner will do significantly more then any single mod(sct from hemifever)
-never use bosch for anything especially O2 sensors
-use the search function on this forum if you have a tech question, it really does work. and you question may of already been awnsered
-add your trucks info to your signature so that you dont have to type it on every post
edit: of course this only affect you if you actually by the truck
Old Oct 24, 2011 | 09:50 PM
Ramcountryboy's Avatar
Ramcountryboy
thanks.
Erik
Jus curious, whats it got for a motor? My dad has a 1999 2500 4x4 with 240,000+ miles with the 5.9L V8, still goin strong!
Old Oct 25, 2011 | 06:38 AM
Novarider's Avatar
Novarider
The transmissions are notoriously weak in these trucks. If it doesn't shift flawlessly your looking at a rebuild which will set you back anywhere from 1-2k depending where you live. Even if it shifts great you still might be looking at a rebuild soon.
I love my truck but if I had known I was going to have to spend $1200 on the transmission just 2 weeks after I bought it I would have gone with another truck.
Old Oct 25, 2011 | 08:12 AM
exmoore's Avatar
exmoore
Thanks for the tips - still thinking about it.....
Oh, and it's a 5.9
Old Oct 25, 2011 | 08:35 AM
kadetklapp's Avatar
kadetklapp
I've got a 99 2500 gas with 230,000 miles. It's got a weak motor, but the rest of the truck is pretty solid. Pay attention to the condition of the rear axle ring and pinion. Make sure the heat works (you do not want to install a new heater core).
