97 V10 8.0L Exhaust Question
Old Oct 25, 2011 | 05:22 AM
pbenzi0585's Avatar
pbenzi0585
Default 97 V10 8.0L Exhaust Question
Hi all, I own a 1997 Dodge Ram ext cab 4x4 V10 and need an exhaust. It rotted away right where the cat meets the midpipe (only on one so far). I'm having a problem finding an exhaust for the truck, all I've been finding is axle back sections, where I need a full catback. Also, I love the swept side exhaust where its dual exhaust exiting behind each tire. Does anyone know where I can find something that will work, or do i have to have a shop custom make it??? If it does have to be custom, anyone know a good shop in or around CT?? Thank you in advance for your input/help.
Pete
Old Oct 25, 2011 | 09:04 AM
Probably have to have it custom bent. I am not in CT, so, can't really point you to any good shops.
Old Oct 25, 2011 | 09:29 AM
Hans_GZP's Avatar
Hans_GZP
I had to custom make mine as well.
Looks like Gibson still makes exhausts for the V10. The only swept side exhausts they have are single outlet. The dual setup they have is a rear exit.
Old Oct 26, 2011 | 02:58 AM
pbenzi0585's Avatar
pbenzi0585
Thanks Hey You and Hans GZP! Any other input would be appreciated.
Hans: I did see the Gibson exhaust, but it looked like just an axle-back system, is it an actual cat-back system?
Old Oct 26, 2011 | 11:08 AM
Hans_GZP's Avatar
Hans_GZP
The cats on these things are pretty far back as it is. So, it should be a catback. There isn't much exhaust past the rear axle. I would also consider replacing the cats while doing the exhaust. They are known to go bad... especially the OEM ones. I ran dual Magnaflow cats on mine because I had one that was rattling pretty bad.
Old Nov 5, 2011 | 10:38 PM
pbenzi0585's Avatar
pbenzi0585
Thanks Hans! I've also just noticed this issue. When I start the truck in the morning, it jumps to 1500 rpm then drops down to around 750rpm.. is that normal? I know in every car I've owned, it usally idles high on a cold start, this truck doesnt. Also, If I drive it around then park it and put it in park, if I dont sit there and let the idle drop below 1000, it idles up to 1500 rpm and sits there for aabout 20-30 seconds and then finally levels out...??? Could this be TPS, IAC, plugs, wires, all of the above???
Thanks
Old Nov 5, 2011 | 11:36 PM
gdstock's Avatar
gdstock
I don't know what the idle speed should be for a V10, but you can download a serevice manual in the FAQ/DIY section. Should be able to find it. fast idle could be vacuum leak or IAC. TPS should not be an issue, if the throttle is closed. Plugs and wire problems should cause it to idle and run rough. You might clean the IAC and see if that fixes the problem. My 5.2L idles around 980 when it is cold then idles down to about 684 after it warms up.
Old Nov 6, 2011 | 08:54 AM
Hans_GZP's Avatar
Hans_GZP
Idle is around 600-700 on the v10. There is a tsb on how the plug wires should be run, but that usually causes a misfire condition. I would definitely replace the IAC first. There aren't many vacuum lines, but it is possible to develop a leak.
Old Nov 8, 2011 | 01:04 PM
pbenzi0585's Avatar
pbenzi0585
Thank you everyone for your input and help. I ordered an IAC today and will be putting that in. I'll start there and hope that solves the problem. Then I'll be changing plugs, wires and cap/rotor.
Old Nov 8, 2011 | 01:36 PM
V-10 doesn't have cap or rotor. It's DIS. (distributorless ignition system) If the parts guy tries to sell you cap and rotor, find a different parts guy.
