ABS Light just came on
Old Oct 25, 2011 | 05:40 PM
i mow grass's Avatar
i mow grass
Default ABS Light just came on
On my way home from work today I noticed my brakes felt very spongy and thought maybe I was just crazy. Well sure enough about 2 miles from my house the Brake & ABS light came on. I checked the fluids as I know absolutely nothing about the brakes except routine maintenance. They seem to go almost all the way to the floor now.
Any ideas on what could be causing this?
Old Oct 25, 2011 | 05:51 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Maybe get out...walk to each wheel and look for any brake fluid leakage. Check out the master cylinder.
hunch?
Old Oct 25, 2011 | 08:13 PM
Brake line running over the gas tank to the rear end. They love to rust out and break.
Old Oct 26, 2011 | 07:57 PM
i mow grass
Thanks guys, I will check the brake lines. However I don't seem to be losing any brake fluid is what is odd to me...
Old Oct 26, 2011 | 08:21 PM
NumbaG's Avatar
NumbaG
I had the same thing happen to me tonight. I was coming to a stop at a red light, had normal pressure on the pedal then both ABS and brake lights came on and the pedal went to the floor. Almost like something let loose. When I got home, I checked all four wheels and didn't see any sign of leaks but it was getting dark and couldn't do a thorough check. Will look in the morning with better light. Anyone have any ideas?
Old Oct 27, 2011 | 12:10 AM
Right above the gas tank. have someone else pump the pedal, while you look for fluid dripping. (make sure there is fluid in the master cylinder TO drip though....)
Old Oct 27, 2011 | 01:34 PM
i mow grass
Alright I will try that this evening, should this be a noticable amount of fluid drippage or will we have to put the pedal for a couple minutes.
Old Oct 27, 2011 | 10:29 PM
NumbaG's Avatar
NumbaG
Found and fixed my problem. Left rear wheel cylinder went out. I had brake fluid all over the inside of the wheel well. When I took off the drum, more fluid poured out. Got the new one in and all is good.
Old Oct 29, 2011 | 03:06 PM
i mow grass
Have found no fluid leakage at all. Should my next step be replace the master cylinder?
Old Oct 29, 2011 | 03:33 PM
Has the level in the M/C gone down? (significantly...)
