231D transfer case
Old Jul 15, 2018 | 06:00 PM
Gregory Don's Avatar
Gregory Don
You really need one from a 98 or newer truck. Shift pattern, and shifter mounting changed in 98......
But would it work
Old Jul 15, 2018 | 06:46 PM
Yup. Bolt right in, probably hook right up. It will have an additional sensor on the output shaft that you don't need, and you will likely need to adjust the linkage. Make note of the new shift pattern as well. You may be able to grab the **** from the donor vehicle, and swap out yours.
Old Jul 15, 2018 | 06:57 PM
Gregory Don
So it will go into the trans fine right
Old Jul 15, 2018 | 07:09 PM
Yep. Nothing really changed in that area.
Old Jul 16, 2018 | 11:02 AM
2bit's Avatar
2bit
Buy a Transfer Case Saver for your new one.
Old Jul 17, 2018 | 11:36 PM
Gregory Don
So I got a Mopar 231 d out of a 1997 1500 I paid 150 is that a good deal I heard Mopars are pretty good
Old Jul 17, 2018 | 11:54 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
That's a good deal... If it works. As mentioned above get the transfer case saver and install it
Old Jul 18, 2018 | 09:07 PM
2bit's Avatar
2bit
Yeah that's pretty good. I paid 125 for mine 2 or 3 years ago.
https://www.ebay.com/itm/New-Gillys-...-/282959161816
Old Jan 3, 2022 | 02:10 AM
anydaddy77's Avatar
anydaddy77
But would it work
you can swap the shift mechanism inside the tc.I dont know what its called off hand but i put a 98 in my 97 and everything works but my speedometer because 98 has the sensor in the rear diff not the tc.
