Ball Joint Installation Question
Old Oct 28, 2011 | 01:40 PM
stewie01's Avatar
stewie01
Default Ball Joint Installation Question
I'm doing ball joints this weekend and I'm trying to get everything ready, got a question. My truck is a 2001 1500 4x2 with bolt on ball joints.
I've been looking through the '01 Service Manual regarding the torque requirements for the bolts and I'm not sure about the torque for the nuts/bolts that hold it to the control arm.
Here are pictures of their design:
Upper
Lower
The service manual under ball joint installation says to "install the lower ball joint nut and tighten to LD: 95ft lbs, HD: 110ft lbs." Upper is the same. My question is that the torque for the castle nut? If so what do I torque the installation bolts to?
There was a member in the Dakota section that did a 4x2 change and I asked about the torque and he posted a picture for the torque ratings on various grades and sizes of bolts. Is there a specific number for these trucks?
Sorry if this confuse's anyone.
Thanks
Old Oct 28, 2011 | 01:43 PM
Looking thru the 01 manual, it appears that they replace the entire control arm, not just the ball joint. Use the chart for torque specs vs. bolt size. Should be one in the manual as well.
Old Oct 28, 2011 | 01:54 PM
stewie01's Avatar
stewie01
Ok, thanks.
Old Oct 28, 2011 | 02:01 PM
stewie01's Avatar
stewie01
So what ball joint nut requires torquing to 95ft lbs? Castle nut or something irrelevant?
Old Oct 28, 2011 | 02:24 PM
That would be the castle nut, Yep. LD designate Light Duty, I think. Not sure what the difference is between LD, and HD on the half tons though.....
Old Oct 30, 2011 | 06:10 PM
stewie01's Avatar
stewie01
Well things happened later then planned but, I got some ball joints today, Duralast from AutoZone, Lifetime Warranty, $50 a joint and I'll tell you things things are BEEFY!!! They should handle whatever my little 2 wheel drive pickup throws at them.
