360 flywheel/v10 clutch
Old Oct 30, 2011 | 01:39 AM
BackwoodsRam's Avatar
BackwoodsRam
Default 360 flywheel/v10 clutch
Simple question. Will a v10 or diesel clutch work with a 5.9gas flywheel
Old Oct 30, 2011 | 02:12 AM
merc225hp's Avatar
merc225hp
Not to sure if this will help you but heres what info I could find.
.................................Size.... spline
5.9L 94 00 88470 - - - 12.0----1 1/8-10
8.0L 94 97 88469 - - - 12 1/4--1 1/4-10
Old Oct 30, 2011 | 10:50 PM
Terribly's Avatar
Terribly
Im curious as to why you ask! Tranny swap?
Old Oct 30, 2011 | 11:05 PM
BackwoodsRam
Theres a hd nv4500 here locally for cheap, and if they clutch combo would work then all i would need is a 360 gas bellhousing
Old Oct 31, 2011 | 04:00 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
^oooooo, xmas coming early?
details details!!!
Old Oct 31, 2011 | 06:39 PM
BackwoodsRam
In a ways, by december i should be getting a 2500good dollar check, and i was gonna regear but my tranny is acting up lately. Im tired of working on it(tranny number 4in 2 years), and the mechanics of the manual sawp are not difficult
Old Oct 31, 2011 | 09:30 PM
BackwoodsRam
update. ive been looking at the flywheel mounting points for a clutch and it just doesnt look like it would work. do you thing itd be doable to have the proper clutch mounting points for a cummins or V-10 clutch machined into a 360 gas flywheel?
Old Oct 31, 2011 | 10:31 PM
Ugly1's Avatar
Ugly1
As long as the bigger clutch fits in the bellhousing and the cable lever/throwout bearing for the 360 works with the bigger clutch it seems like if you got the pressure plate mounted it would have to work. You may need a different driveline too.
Edit I'm just guessing at this so beware.
Old Oct 31, 2011 | 10:37 PM
Gerehead8's Avatar
Gerehead8
Remember whatever flywheel you use it must be balanced to match the 360 Magnums external balance.
Old Oct 31, 2011 | 11:28 PM
BackwoodsRam
Well if i were to do this swap i would be using a stock 360 gas flywheel. The every thing is the same for the ld and hd 4500's except for the splines
